3 Replies Latest reply on Sep 29, 2009 4:34 AM by kglad
    LoadClips work/don works
    bennos89 Level 1
      Hi people,
      I have some trouble with my loadClip. Everytime I used the loadclip function, 8 swf will be load at one go. However, something the loadclip manage to all the swf and sometime it manage to load only 6 to 7 swf. All my 8 swf have different file size. And I need to more than 80 to 100 plus swf.
      Is there way to fix this bug or ?
      Here is my code
      //Preloader Two
      var listenerPage:Object= new Object();
      var mcLoaderPage:MovieClipLoader= new MovieClipLoader();
      mcLoaderPage.addListener(listenerPage);
      listenerPage.onLoadStart= function(target:MovieClip):Void
                countPages++;
      listenerPage.onLoadInit= function(target:MovieClip):Void
                countPages--;
                setCheckPageLoaded(target);                                 ---> This function is to remove Preloader MovieClip
                if((countPages== 0) && (leftToLoad > 0))
                        fBoolean= false;
                        leftToLoad-= 2;
                        counterTwo+= 2;
                        twoPerPage+= 2;
                        aCountPage(counterTwo, twoPerPage);               -----> This function is to load another 8 swf once the preivous 8 swf is load finish everything is complete.
      Thank
      Benson
        • 1. Re: LoadClips work/don works
          there's a limit to the amount flash will similtaneously download.  if you're publishing for a fp version that can't 8, you could try 6 at a time.  i believe when i last tested (fp 6), the limit was 4.
          but there's really no reason to load more than 1 at any one time.  it won't speed the overall load progress.  so, you may as well load sequentially, one swf at any one time.
          • 2. Re: LoadClips work/don works
            bennos89 Level 1
            Thanks for your reply. I would like to ask more details what do you mean fb?
            Are you trying to say flash only limit to 4 similtaneously download at one go? Therefore, you are suggesting to load per swf. Once completed? And you say the version might affect the the mcloader?
            Currently, my version for the swf is 9.
            I could change to the version 10 if help to solve the problem.
            Hope to see your reply as soon as possible.
            At the same time I would like to ask whether I can have 3 loadclip listener? Loading/not loading at the same time
            Benson
            • 3. Re: LoadClips work/don works
              fp = flashplayer.
              there's a limit to the number of simultaneous downloads.  do some testing to see if it's fp dependent and i'm pretty sure it is browser dependent, too.
              and yes, you can have more than one listener for each moviecliploader.
