0 Replies Latest reply on Sep 28, 2009 7:24 AM by Darrell Loverin
    [svn:fx-trunk] 10633: Use styleManager instance instead of StyleManager singleton ( framework and compiler generated code)
    Darrell Loverin Level 4
      Revision: 10633
      Author:   dloverin@adobe.com
      Date:     2009-09-28 06:24:30 -0700 (Mon, 28 Sep 2009)
      Log Message:
      Use styleManager instance instead of StyleManager singleton (framework and compiler generated code)
      Modified compiler generated style code for the FlexInit class. The style related changes are only available with the -keep option. AST generation is coming later.
      Only the framework project is changed here. The other projects are will be changed soon.
      QE notes: None.
      Doc notes: None.
      Bugs:
      Reviewer: Alex and Paul
      Tests run: checkintests, all Mustella tests(no new failures)
      Is noteworthy for integration: no.
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/Accordion.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/DividedBox.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/Form.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/FormItem.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/accordionClasses/Accordion Header.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/utilityClasses/CanvasLayou t.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/ButtonBar.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/ComboBox.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/DataGrid.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/DateChooser.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/DateField.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/Label.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/List.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/MenuBar.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/SWFLoader.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/Tree.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/dataGridClasses/DataGridColu mn.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/dataGridClasses/DataGridHead er.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/dataGridClasses/DataGridHead erBase.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/dataGridClasses/DataGridItem Renderer.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/listClasses/ListBase.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/listClasses/TileBase.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/textClasses/TextRange.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/Application.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/Container.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/LayoutContainer.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UITextField.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/effectClasses/SetStyleActionI nstance.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/events/Request.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/CursorManagerImpl.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/DragManagerImpl.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/dragClasses/DragProxy.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/modules/ModuleManager.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/ProgrammaticSkin.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/halo/AccordionHeaderSkin.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/halo/BusyCursor.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/halo/ButtonBarButtonSkin.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/halo/ButtonSkin.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/halo/CheckBoxIcon.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/halo/ComboBoxArrowSkin.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/halo/DataGridHeaderBackgroundSk in.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/halo/DateChooserMonthArrowSkin. as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/halo/HaloBorder.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/halo/MenuBarBackgroundSkin.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/halo/NumericStepperDownSkin.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/halo/NumericStepperUpSkin.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/halo/PopUpButtonSkin.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/halo/ProgressBarSkin.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/halo/ProgressIndeterminateSkin. as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/halo/ProgressTrackSkin.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/halo/RadioButtonIcon.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/halo/ScrollArrowSkin.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/halo/ScrollThumbSkin.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/halo/ScrollTrackSkin.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/halo/SliderThumbSkin.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/halo/SliderTrackSkin.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/halo/TabSkin.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/halo/TitleBackground.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/states/SetStyle.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/CSSStyleDeclaration.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/IStyleManager2.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/IStyleModule.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/StyleManager.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/StyleManagerImpl.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/StyleProtoChain.as
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/CompilerConfiguration.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StyleDef.vm
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StyleModule.vm
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/gen/ClassDefLib.vm
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/lang/StandardDefs.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_en.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/PreLink.java
