11 Replies Latest reply on Oct 26, 2009 4:24 PM by pafeth
    Reduce Over exposure
    sundark
      Too much light on my daughters classical dance recital resulted in washing out her facial expressions.
      I tried to adjust contrast/brightness/levels. But they all resulted in reducing the light of overall picture including the stage.
      I want to isolate my daughter and make the correction.
      I would appreciate any help on this.
      Thx
      Sundar
      Using Adobe Premiere pro CS4/AE CS4
        • 1. Re: Reduce Over exposure
          Harm Millaard Level 7
          Copy the clip to a higher track, apply a matte on this copy and then use levels to correct the overlaying clip within the matte only.
          • 2. Re: Reduce Over exposure
            Jeff Bellune Level 5
            My choices:
               1. Color Finesse in AE.
               2. Fast Color Corrector in Pr.
            In either case, set the CC to operate only on the highlights.  In AE you
            can mask the area to be CC'd before you turn it over to CF.
            Be warned: although you can often rescue shadow detail, once the
            highlights get blown out they're gone forever.  Don't expect miracles in
            this case.
            -Jeff
            • 3. Re: Reduce Over exposure
              You cannot fix overexposure.
              What is not there in pixels Premiere or AE cannot magically produce.
              • 4. Re: Reduce Over exposure
                sundark Level 1
                Jeff
                Thx. I will try it.
                As she moves around the stage it may be difficult to mask one specific area
                Thx again
                Sundar
                Sent from my iPhone
                • 5. Re: Reduce Over exposure
                  sundark Level 1
                  Thx. I will try it
                  Sundar
                  Sent from my iPhone
                  • 6. Re: Reduce Over exposure
                    the_wine_snob Level 9
                    Along with the suggestions, you might also want to add Effect>Shadow & Highlight, take if OFF of Auto and experiment with the settings. I usually apply this before my Levels(NOT Auto Levels), and then once Levels have been adjusted, go back to S & H.
                    Luma Curves can also help.
                    As Ann points out, this is a cosmetic fix, as blown highlights contain little, if any data. You are only doing thing to approximate properly exposed footage, and cannot reclaim what is not there. Still, one can usually "improve" on the unaltered footage to some degree.
                    PS - doesn't CS4 offer Blending Modes now? If so, one might want to dupe the Clip, per Harm's suggestion and change the Blending Mode to Multiply. If it does not, then never mind...
                    • 7. Re: Reduce Over exposure
                      Yes CS4 has blending mode. But how does one multiply 0 (zero)?
                      • 8. Re: Reduce Over exposure
                        Ann,
                        Thanks for the clarification on CS4. That was what I thouight.
                        Of course 0 will not multiply, but any value >0 will, Where the highlights are totally gone, they are gone. Where they're "nearly gone," there are values to multiply. What one is doing is helping to enhance the overall, and some help can come from Blending Modes, Levels, and even Highlight and Shadow corrections, plus the gamma settings in Fast Color Corrector, etc. Yes, it's a bit of an "illusion," but sometimes that illusion will be enough to save a Clip.
                        For 0, a reshoot would be in order, if it occupies too much of the frame.
                        • 9. Re: Reduce Over exposure
                          sundark Level 1
                          Thanks for your ideas.
                          I wasn't precise when I said that the picture was washed out.
                          It wasn't that bad. The details are still there. But there is a a shine/glow on her face from the extra light. I will try the blend mode.
                          Thx
                          Sundar
                          • 10. Re: Reduce Over exposure
                            That is great news. As Ann, and others, point out, if you have a value of 0, there is no detail there. At least you have some detail.
                            Along the lines of what I now think you're doing, here's a Tutorial on "softening skin tones." In your mind, think about "toning down highlights." Just blank your mind for a moment, and imagine.
                            • 11. Re: Reduce Over exposure
                              pafeth
                              I have the same problem with my clips. The bad news is I am new to Adobe. The good news is there are people that can help whether it is possible to remove light exposure or not.  Now can someone teach me where to go in either after effect  or premiere pro cs4 to solve this. Please help.
