3 Replies Latest reply on Sep 29, 2009 8:13 AM by Krogman
    Incomplete Image created from SQL Image type using cfimage
    Krogman
      Hello
      Has anyone run into this problem? I have an SQL 2005 database with a column in a table of type image (created from a commercial product). When I use the CFIMAGE tag to create or write the image to a browser (or disk) the image is nearly always truncated (see below). The dimensions of the image are correct, but most of image data is missing. Here is an example:
      I've tried using the cfsetting with a large timeout value, but it makes no differnce. Nearly 90% of the images created from the database are truncated like this when created using the cfimage tag. When viewed or exported from the original application (and database) it's fine. Does anyone have any ideas I can try to figure this out or work around the problem?
      Thanks, Joe
