0 Replies Latest reply on Sep 28, 2009 11:22 AM by Paul Reilly
    [svn:fx-trunk] 10647: * A batch of compiler fixes.
    Paul Reilly Level 1
      Revision: 10647
      Author:   preilly@adobe.com
      Date:     2009-09-28 10:21:59 -0700 (Mon, 28 Sep 2009)
      Log Message:
      • A batch of compiler fixes.
      QE notes:
      Doc notes:
      Bugs: SDK-22258, SDK-21547, SDK-22879, SDK-23169, SDK-23336
      Reviewer: Edwin (ActionFactory.java), Ryan (VideoPlayer.as), Corey
      Tests run: full cyclone
      Is noteworthy for integration: Yes, HostComponent, SkinPart, and
                                     SkinState metadata is now validated by
                                     the compiler.
      Code-level description of changes:
        frameworks/projects/spark/src/spark/skins/spark/BorderSkin.as
          Made HostComponent fully qualified.
        frameworks/projects/spark/src/spark/components/VideoPlayer.as
          Updated SkinState metadata to reflect revision 7732.
        modules/swfutils/src/java/flash/swf/ActionFactory.java
          Made getLabel() more bullet proof.
        modules/compiler/src/java/flex2/compiler_en.properties
          Added as3.HostComponentExtension.HostComponentClassNotFound,
          as3.HostComponentExtension.MissingSkinPart,
          as3.HostComponentExtension.MissingSkinState,
          as3.SyntaxTreeEvaluator.OnlyOneHostComponentAllowed, and
          as3.SyntaxTreeEvaluator.SkinPartsMustBePublic.
        modules/compiler/src/java/flex2/compiler/CompilationUnit.java
          Replaced hasHostComponentMD with hostComponentMetaData.
        modules/compiler/src/java/flex2/compiler/as3/genext/GenerativeClassInfo.java
          Modified getImports() to support Vectors.
        modules/compiler/src/java/flex2/compiler/as3/HostComponentEvaluator.java
          Removed, because we really don't need to evaluate the AST again to
          find the HostComponent metadata since SyntaxTreeEvaluator has
          already found it.
        modules/compiler/src/java/flex2/compiler/as3/AbstractSyntaxTreeUtil.java
          Modified generateTypeExpression() and generateVariable() to
          support passing in a position.
        modules/compiler/src/java/flex2/compiler/as3/SyntaxTreeEvaluator.java
          Modified evaluate(Context, MetaDataNode) to handle .
          Modified processHostComponentMetaData() to store the node in the
          CompilationUnit and report an error if more than one HostComponent
          is found.
          Added processSkinPartMetaData().
        modules/compiler/src/java/flex2/compiler/as3/HostComponentExtension.java
          Refactored to handle what HostComponentEvaluator was doing, plus
          validate HostComponent, SkinPart and SkinState metadata.
        modules/compiler/src/java/flex2/compiler/mxml/rep/init/ValueInitializer.java
          Modified generateDefinitionBody() to store a line number mapped
          position for the variable definition.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-22258
          http://bugs.adobe.com/jira/browse/SDK-21547
          http://bugs.adobe.com/jira/browse/SDK-22879
          http://bugs.adobe.com/jira/browse/SDK-23169
          http://bugs.adobe.com/jira/browse/SDK-23336
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/VideoPlayer.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/BorderSkin.as
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilationUnit.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/AbstractSyntaxTreeUtil.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/HostComponentExtension.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/SyntaxTreeEvaluator.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/genext/GenerativeClassInfo.ja va
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/init/ValueInitializer.ja va
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_en.properties
          flex/sdk/trunk/modules/swfutils/src/java/flash/swf/ActionFactory.java
      Removed Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/HostComponentEvaluator.java
