There is a problem with the Search display function in WebHelp Pro project published to RHServer 8 where the apostrophe in a topic title is replace by the html code (&apost;) when it displays in the Search list panel. I'm assuming that same problem applies to published WebHelp. Again, this problem does NOT occur in my current RH7 FlashHelp project or when I view RH8 FlashHelp Pro version to was published to RHServer 8.
How do I make WebHelp Pro project's TOC and Search functions behave like FlashHelp? There shouldn't be a difference between these 2 layouts.
These are both bugs and I'd urge you to report them as such using this link. They more of us that report it, the more likely it is to be fixed in an update/patch. For the TOC display problem the workarounds. I have posted a blog entry on this here.
Read the RoboColum(n).
I've submitted both issues as WebHelp/WebHelp Pro bugs.
