2 Replies Latest reply on Sep 29, 2009 12:41 AM by daniele.gigola
    text tracking info
    daniele.gigola
      Once enable the tracking text option how to select the path.
      Every time I do it the text move to right but I want move text from center to right/left while disappear..
      thanks
      Bye
        • 1. Re: text tracking info
          I don't really understand you, I'm afraid. The text on path uses a special first margin/ right margin property (after the mask path has been assigned it becomes active) to align with the path. Changing those values will allow to center the path in case the default center align paragraph style doesn't look as expected. For animating the tracking, you will have to use a text animator, not the options in the characters panel.
          Mylenium
          • 2. Re: text tracking info
            daniele.gigola Level 1
            ok solved...there was a problem with the anchorage point that wasn't in the center.
            thanks anyway
            bye !!
            Daniele
