0 Replies Latest reply on Sep 28, 2009 3:04 PM by Chet Haase
    [svn:fx-trunk] 10657: Fixes for 4 unrelated effects bugs.
    Chet Haase Level 3
      Revision: 10657
      Author:   chaase@adobe.com
      Date:     2009-09-28 14:03:46 -0700 (Mon, 28 Sep 2009)
      Log Message:
      -     Nested parallel effects were not dealing with targets in children. (CompositeEffect)
      -     Composite effects were capturing values for child effects property (need to have child effects only capture values for their targets, not any other targets in the overall effect) (CompositeEffect)
      -     3D Transform effects were not correctly dealing with transform centers that were staying in place during the effect. We needed to force the postTranslationX/Y properties to be animated, even though they might be unchanging. (AnimateTransform)
      -     Supplying Fade in a trigger for a popupAnchor caused an RTE due to a bad assumption about components vs groups. This fix doesn?\226?\128?\153t actually made fading work (new effects don?\226?\128?\153t deal with triggers), but it prevents the crash (EffectManager)
      QE notes: None
      Doc notes: None
      Bugs: SDK-23413, SDK-23381, SDK-23366, SDK-23460
      Reviewer: Jason
      Tests run: checkintests, Mustella spark/effects, mx/effects
      Is noteworthy for integration: Yes (downstream teams asked for 23460 fix)
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-23413
          http://bugs.adobe.com/jira/browse/SDK-23381
          http://bugs.adobe.com/jira/browse/SDK-23366
          http://bugs.adobe.com/jira/browse/SDK-23460
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/CompositeEffect.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/EffectManager.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/AnimateTransform.as
