4 Replies Latest reply on Jul 11, 2008 10:44 AM by SwitchShift
    XML e4x dot notation problem
    SwitchShift
      Hi, I'm having a problem using an rss feed from youtube. I've successfully gotten the xml in an XML variable theYResult, and can bind it to an mxml text area, however I cannot seem to use dot notation to access the data, even though I received it through an HTTPService with responseFormat = "e4x". The xml has a format of:
      <feed>
      <id></id>
      <entry></entry>
      <entry></entry>
      <entry></entry>
      </feed>
      However, trying to get an XMLList of theYResult.entry returns 0 length, and it is this list that I'm interested in. I'm attaching the entire code, running it will display the xml in a text area at the bottom of the screen, and in debug mode will attempt to trace various elements that I think should be accessible using dot notation. Thanks for any help in advance.
