1 Reply Latest reply on Sep 29, 2009 5:05 AM by Ned Murphy
    [AS2] how to access a TextInput using its name?
    popotskie
      I want to change the text of a TextInput using its name for example.
      ("name1").text = "123"
      or is it possible to create an array of components?:
      txt[0].text = "123"
      how to do it? thanks in advance
        • 1. Re: [AS2] how to access a TextInput using its name?
          I'm not certain what your intention is, but if the instance name of the textfield is name1, then you can assign its text using:
          name1.text = "123";
          If you have an array of the instances, the same applies, so long as the array is assigned the instances and not string versions of their names.
          var txt:Array = new Array(name1);
          txt[0].text = "123";
          If you have an array with strings of the instances names, then you need to use bracket notation to have the strings interpretted as instances...
          var txt:Array = new Array("name1");
          this[txt[0]].text = "123";
