0 Replies Latest reply on Sep 29, 2009 6:12 AM by sense
    HTMLLoader problem with comboBox
    sense
      hi guys
      I'm trying to loader pdf file using XML to retrieve the URL  and I have CombBox to list all the files ,and I need to load another file every time I change the silder for the CombBox
      the problem is the pdf file load only first time and dosent  change if I select another one from the list, I dont know what the the probelm I tried manything like removeChild and I tried to use container but no change, only first time the file loaded
      this is the code
      cb_list.addEventListener(
      SliderEvent.CHANGE,changehandler);
      function changehandler(e:Event):void {
          var sort1:String=cb_list.value;
          var id:String = myXML.tip.(title == sort1).@ID.toXMLString();
           //trace(id)
          var slectedtip = myXML.tip.(title == sort1).fulltip.text();
          tit_label.text=myXML.tip.(@ID == id).title .text();
          date_label.text=myXML.tip.(@ID == id).date.text();
          full_tip.text=myXML.tip.(@ID == id).fulltip.text();
           var flashfileURL = myXML.tip.(@ID == id).picURL.text();
          swfURL.text=flashfileURL;
          var url:String = new String();
          url= myXML.tip.(@ID == id).picURL.text().toXMLString();
          var requestpdf:URLRequest=new URLRequest(url);
           var container:Sprite = new Sprite();
          var pdf = new HTMLLoader();
          pdf.height=stage.stageHeight-150;
          pdf.width=stage.stageWidth-270;
          pdf.y=100;
          pdf.x=260;
          pdf.load(requestpdf);
             pdf.addEventListener(Event.COMPLETE, completeHandler);
          function completeHandler(event:Event):void {
              addChild(pdf);
