0 Replies Latest reply on Sep 29, 2009 5:43 AM by Darrell Loverin
    [svn:fx-trunk] 10672: Use styleManager instance instead of the StyleManager singleton ( airframework, halo, and spark projects)
    Darrell Loverin Level 4
      Revision: 10672
      Author:   dloverin@adobe.com
      Date:     2009-09-29 04:43:11 -0700 (Tue, 29 Sep 2009)
      Log Message:
      Use styleManager instance instead of the StyleManager singleton (airframework, halo, and spark projects)
      A couple updates in the framework project as well.
      QE notes: None.
      Doc notes: None.
      Bugs:
      Reviewer: Alex
      Tests run: checkintests
      Is noteworthy for integration: no.
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/airframework/src/mx/core/Window.as
          flex/sdk/trunk/frameworks/projects/airframework/src/mx/core/WindowedApplication.as
          flex/sdk/trunk/frameworks/projects/airframework/src/mx/managers/NativeDragManagerImpl.as
          flex/sdk/trunk/frameworks/projects/airframework/src/mx/skins/halo/ApplicationTitleBarBack groundSkin.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/effectClasses/SetStyleActionI nstance.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/ProgrammaticSkin.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/IStyleModule.as
          flex/sdk/trunk/frameworks/projects/halo/src/mx/skins/halo/AccordionHeaderSkin.as
          flex/sdk/trunk/frameworks/projects/halo/src/mx/skins/halo/BusyCursor.as
          flex/sdk/trunk/frameworks/projects/halo/src/mx/skins/halo/ButtonBarButtonSkin.as
          flex/sdk/trunk/frameworks/projects/halo/src/mx/skins/halo/ButtonSkin.as
          flex/sdk/trunk/frameworks/projects/halo/src/mx/skins/halo/CheckBoxIcon.as
          flex/sdk/trunk/frameworks/projects/halo/src/mx/skins/halo/ComboBoxArrowSkin.as
          flex/sdk/trunk/frameworks/projects/halo/src/mx/skins/halo/DataGridHeaderBackgroundSkin.as
          flex/sdk/trunk/frameworks/projects/halo/src/mx/skins/halo/DateChooserMonthArrowSkin.as
          flex/sdk/trunk/frameworks/projects/halo/src/mx/skins/halo/HaloBorder.as
          flex/sdk/trunk/frameworks/projects/halo/src/mx/skins/halo/MenuBarBackgroundSkin.as
          flex/sdk/trunk/frameworks/projects/halo/src/mx/skins/halo/NumericStepperDownSkin.as
          flex/sdk/trunk/frameworks/projects/halo/src/mx/skins/halo/NumericStepperUpSkin.as
          flex/sdk/trunk/frameworks/projects/halo/src/mx/skins/halo/PopUpButtonSkin.as
          flex/sdk/trunk/frameworks/projects/halo/src/mx/skins/halo/ProgressBarSkin.as
          flex/sdk/trunk/frameworks/projects/halo/src/mx/skins/halo/ProgressIndeterminateSkin.as
          flex/sdk/trunk/frameworks/projects/halo/src/mx/skins/halo/ProgressTrackSkin.as
          flex/sdk/trunk/frameworks/projects/halo/src/mx/skins/halo/RadioButtonIcon.as
          flex/sdk/trunk/frameworks/projects/halo/src/mx/skins/halo/ScrollArrowSkin.as
          flex/sdk/trunk/frameworks/projects/halo/src/mx/skins/halo/ScrollThumbSkin.as
          flex/sdk/trunk/frameworks/projects/halo/src/mx/skins/halo/ScrollTrackSkin.as
          flex/sdk/trunk/frameworks/projects/halo/src/mx/skins/halo/SliderThumbSkin.as
          flex/sdk/trunk/frameworks/projects/halo/src/mx/skins/halo/SliderTrackSkin.as
          flex/sdk/trunk/frameworks/projects/halo/src/mx/skins/halo/TabSkin.as
          flex/sdk/trunk/frameworks/projects/halo/src/mx/skins/halo/TitleBackground.as
          flex/sdk/trunk/frameworks/projects/spark/src/mx/controls/dataGridClasses/TLFDataGridItemR enderer.as
          flex/sdk/trunk/frameworks/projects/spark/src/mx/core/UITLFTextField.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/ItemRenderer .as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/supportClasses/SetActionInstan ce.as
