0 Replies Latest reply on Sep 29, 2009 7:34 AM by CoreyRLucier
    [svn:fx-trunk] 10674: PARB related API tweaks for the 'simplified skins' work item.
    CoreyRLucier Adobe Employee
      Revision: 10674
      Author:   clucier@adobe.com
      Date:     2009-09-29 06:34:39 -0700 (Tue, 29 Sep 2009)
      Log Message:
      QE notes: None
      Doc notes: None
      Bugs: None
      Reviewer: Chet/Glenn
      Tests run: Checkin
      Is noteworthy for integration: No
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/spark/SparkChromeWindowed ApplicationSkin.mxml
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/spark/WindowedApplication Skin.mxml
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/spark/windowChrome/MacTit leBarSkin.mxml
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/spark/windowChrome/TitleB arSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ApplicationSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ButtonBarFirstButtonSkin.m xml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ButtonBarLastButtonSkin.mx ml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ButtonBarMiddleButtonSkin. mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/CheckBoxSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/DefaultButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/DropDownListButtonSkin.mxm l
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/DropDownListSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/HScrollBarSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/HScrollBarThumbSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/HScrollBarTrackSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/HSliderSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/HSliderThumbSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/HSliderTrackSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ListSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/NumericStepperSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/NumericStepperTextInputSki n.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/PanelSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/RadioButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ScrollBarDownButtonSkin.mx ml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ScrollBarLeftButtonSkin.mx ml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ScrollBarRightButtonSkin.m xml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ScrollBarUpButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ScrollerSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/SkinnableContainerSkin.mxm l
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/SkinnableDataContainerSkin .mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/SpinnerDecrementButtonSkin .mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/SpinnerIncrementButtonSkin .mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/SpinnerSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/TextAreaSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/TextInputSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ToggleButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/VScrollBarSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/VScrollBarThumbSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/VScrollBarTrackSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/VSliderSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/VSliderThumbSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/VSliderTrackSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/VideoPlayerSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/normal/FullSc reenButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/normal/MuteBu ttonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/normal/PlayPa useButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/normal/ScrubB arSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/normal/ScrubB arThumbSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/normal/ScrubB arTrackSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/normal/Volume BarSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/normal/Volume BarThumbSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/normal/Volume BarTrackSkin.mxml
