6 Replies Latest reply on Oct 1, 2009 6:39 PM by David_F57
    Using Zend Framework
    David_F57 Level 5
      Is anyone using zend with Wamp successfully, I have revisited this "framework" a few times but revert back to amfphp because at least it works, now when I go to start with zend it copies itself to my host then when I go to create classes I get an error if I try to proceed wamp gets trashed.
      image of error attached.
      David
        • 1. Re: Using Zend Framework
          jean-fabre
          I had the same problems, and it's not linked to using wamp I think ( using easyphp).
          I think it's because it needs to be installed at the root level of your web server ( in the www folder), and flash builder actually installed it in my project folder, so I copied the zend framework in my www folder and it worked ( I did not delete the original folder tho).From then on, services worked fine.
          anyway, try moving the zend framework folder around, it should do then.
          • 2. Re: Using Zend Framework
            David_F57 Level 5
            Thanks for the tip, but I tried moving things around, zend did actually install into the www folder of wamp but it seems there are bits missing such as a gateway. Anyway vapour expands to fill space which is then bloat which pretty much covers zend, an over-engineered piece of bloatware. Anyway i'll use the old amfphp, zend just isn't worth the hassle(which pretty much is where the zend framework has always been) .
            • 3. Re: Using Zend Framework
              MartyO
              can I suggest another option
              check out the ZendServer Community edition - has everything WAMP has + loads more
              I'm having some success using Flex 4 / Zend - hurry up MAX so more examples code comes out
              DM me if you need some - martin at hunome dot com
              • 4. Re: Using Zend Framework
                David_F57 Level 5
                thanks, I will have a look at this, never hurts to try
                • 5. Re: Using Zend Framework
                  Mayank (Adobe) Adobe Employee
                  Did the server settings entered in the new project wizard validate? Which version of WAMP are you trying to use?
                  -mayank
                  • 6. Re: Using Zend Framework
                    David_F57 Level 5
                    -mayank
                    The server was validated and zend installed into the wamp webfolder correctly, its just that when attempting to create a sample class things fail then wamp becomes unusable even after a reboot. I use wamp 2.0i.  Anyway the upshot is that from the beginning the zend framework has been more a hinderance than a help its a pity that Adobe didn't strike a deal with the author of AMFPhp(who unfortunately went to zend) and just give us a proper set of AMF classes instead of a low performance framework which is more about bloat than functionality and even less about AMF.
                    Anyway as I said earlier i have better things to do with my time and I now have the deprecated parts of AMFPhp sorted so its back to something that works without the headaches.
                    David.
