3 Replies Latest reply on Oct 9, 2017 9:29 PM by stevep14003173
    Exporting 5.1 ac3 audio from Premiere Pro CS4
    AmberCEGraham
      Hi there,
      I wonder if anybody can help me out with exporting 5.1 ac3 audio from Premiere CS4 version 4.1.0?
      I have a 3min long HD 5.1 clip that I need to cut down to 60seconds and add fade transitions to. The final clip will be used in a media player with very specific spec - the clip needs to remain HD 1080p with a frame rate of 29.97 and a maximum CBR of 38. The audio must be 5.1 aac. The format can be mpeg 2 or h.264. The overall quality loss needs to be minimal.
      Up to now I have been cutting up footage that only needs to be stereo and I found the best way to to this while keeping quality was to use Prem Pro and export as mpeg 2 1080p 29.97, quality:5, bitratre: CBR 38, audio as mpeg layer 2 (as these clips were stereo only). These clips played back fine and looked great so I wanted to keep the 5.1 clip process as close to this as possible.
      So far all I have been able to get from Premiere Pro is an audio codec called DVD_LPCM which the media player will not recognise. I'm a bit of a novice when it comes to 5.1 audio so I may be doing something obviously wrong...
      - I have purchased the 5.1 surcode codec and its activated.
      - I have started a new AVCHD (I need 1920x1080) 1080p 29.97  project with a 5.1 audio master
      - The orignal file is an mpeg which I have pulled into PPro and selected Clip > Audio > Breakout to mono
      - I take the 6 mono channels in the project panel and put them into thier own mono tracks in the sequence.
      - the video I use is the original mpeg with the 5.1audio muted in the sequence.
      - When i select each track in the project panel and go to Clip > Audio > Source channel mappings, I see that track has already been allocated a source channel. So I go to the Audio Mixer panel and adjust the 5.1 panners for each tyrack according to what the Source Channel Mapping window has told me - Audio 1 is is L, audio 2 is R, audio 3 is LS, 4 -  Rs, 5- C and 6- LFE
      - I cut the video and all the mono track to the 60seconds I need and export using these settings:
      Video - exactly as before
      Audio -
      Format - Dolby Digital, Codec - SurCode, Audio Coding Mode: 3/1 (L, R, C, LFE, Ls, Rs - 5.1 Surround), LFE: on.
      The clip exports with DVD_LPCM 5.1 audio. Is it to do with the AVCHD preset? Could anyone help me get aac? Any help would be appreciated.
      Thanks in advance
        • 1. Re: Exporting 5.1 ac3 audio from Premiere Pro CS4
          Jim_Simon Level 8
          That's a contradiction.  AC3 and AAC are two differernt codecs.  Which do you need?
          • 2. Re: Exporting 5.1 ac3 audio from Premiere Pro CS4
            the_wine_snob Level 9
            Using AME and the SurCode Plug-in, here's how the dialog screen looks for the Audio Tab in PrPro 2.0. It should be similar in CS4:
            You do have the Minnetonka SurCode DD 5.1 SS plug-in, right?
            Good luck, and hope that this is helpful.
            PS - note that in the screen-cap, I have composited the dialog box, as though it fully displayed, with no need to scroll it. Depending on your display, you may need to scroll, and your scroll bars will look different from what you see here - just ignore that part of it.
            Message was edited by: the_wine_snob - Added PS
            • 3. Re: Exporting 5.1 ac3 audio from Premiere Pro CS4
              stevep14003173
              Hi Wine Snob
              I've got a similar problem. I am using CS 5 and have been able to import an AC3 file (the file was created in another program). It plays fine. All good on that front.
              I want to export it as an AC3 but can't see any options in the sound section for AC3 or any other dolby encoding.
              Does: Minnetonka SurCode DD 5.1 SS plug-in, take care of this?
              Ordinarily I would use Audacity (saw the forum discussion: Free AC3 encoding workflow ) , but I have cut a section of the vision and sound out in two places, assuming it would export fine from Premiere. So I didn't keep an eye on the number of frames. So transferring over to Audacity could get messy. If SurCode does the job and doesn't cost an arm and a leg, I'd be happy to buy it.
              Appreciate your previous tips. And any other advice you might have.
