Bonjour,
The pdf file is well protected and my students have access to «all the Reader's tools».
Yet, if they save their work, they can't access their file anymore.
They get a message stating that since the file had been changed the tools extensions are no longer available.
I want them to write notes on their files during their exams.
I want them to be able to save their pdf files and go back to it after a few minutes or hours.
How do I correct this?
Armand
Teacher at
University of Sherbrooke
Quebec Canada
Solved! Go to Solution.
Views
Total Likes
Ok I found the problem .....your certificate that you use to Reader Extend the document has expired. See attached screen shot. I assume that you are using an evaluation copy of Acrobat and that is how you Reader Extended the doc.
Paul
Views
Total Likes
Can you post a sample of the form so we can see what has been done to the form?
Paul
Views
Total Likes
You mean on the pdf file!
Anything written on the pdf file and saved, (either with same name or a new file name) prevents any use of the Reader Tools at the next opening
If I put a circle, a square or write something, at opening I get a message which read as follow (I'm translating).
«This document has activated the extended functions of Acrobat Reader. It has been modified since its creation
and the extended extensions are no longer available. Contact the author of the original document.»
Hope I'm being clear
Armand
Views
Total Likes
I assume that you are Reader Extending the document before giving it to the user...right? Are you choosing the allow commenting right?
Thats why I wanted you to post the form so I can check to see what rights were applied to it.
Paul
Views
Total Likes
Here is the form
Views
Total Likes
I guess you'Il need a login info
User: para8888
Pass: 8888para
Views
Total Likes
When opening in Acrobat Pro 9, I can see that:
Write permissions are set to «YES»
Armand
Views
Total Likes
Paul
Views
Total Likes
This is exactly it
We are on a trial version and the Adobe rep extended LiveCycle trial
period and must have forgotten
to extend the Extension package
Thanks very much
I'm calling him at this very moment
Armand Paré
Chargé de cours
Université de Sherbrooke
Bureau: K1-4084
Téléphone: 819-821-8000 poste 62788
Sans frais: 1-800-267-8337 poste 62788
Site du Programme PEP-CGA USherbrooke
Paulhttp://forums.adobe.com/servlet/JiveServlet/showImage/12430/screen1.png
Views
Total Likes
Thanks again Paul
You've been very helpful.
From Armand
Views
Total Likes
