2 Replies Latest reply on Oct 1, 2009 1:09 PM by Mark Pleasant
    How to automate saving single swf files?
    Mark Pleasant
      Right off the bat.... I'm a newbie...it will be obvious I'm sure. This is what I'm doing....
      01. I take a PowerPoint slide show and convert it to an  .emf (MetaData) PowerPoint show in power point.
                ( an aside...I have used enhance MetaData and regular MetaData and haven't noticed any difference. No biggie I guess)
      02. I then load the Flash CS4 stage with the .emf PowerPoint slide show.
      03. Do some clean-up.
      04 I then must save individual .swf files of the timeline. ( I notice there doesn't seem to be a key board stroke for Export Image... that seems weird)
      05. I do all the mouse clicks and save the .swf's in a folder. For 80 or more slide per show this is very tedious I must say. Clicking, numbering, saving, advanceing, clicking, numbering saving...etc. I typically end up with a folder with ...Slide_01, Slide_02, Slide_03 etc. which is what I want.
      What is the best way to automate this process? I'm not a programmer, but is a Macro program what I need. Or is there a way in Flash to simplify this process     ..of course I'm not a programmer.
      Thanks!
      mp
        • 1. Re: How to automate saving single swf files?
          RossRitchey Level 4
          1. You can customize the keyboard shortcuts in Flash.
               - Go to Edit/Keyboard Shortcuts
               - When the dialog opens, you must duplicate the set by clicking the left-most button next to the Current Set drop-down (the tool-tip displays "Duplicate Set" when you hold the mouse over it for a second)
               - Navigate the tree into File/Export
               - Select the Export Image node
               - Click the "+" button in the Shortcuts area
               - Hit the key combination you want to use for this
               - Click the "Change" button
               - Resolve any conflicts the shortcut you set creates
               - Click OK
          2. Is there a reason you are exporting each slide as a SWF?  Why not an image format, like JPG, PNG, or GIF?
          • 2. Re: How to automate saving single swf files?
            Mark Pleasant Level 1
            Thanks! That should be a huge help.
            As for why .swf's I could be wrong but the swf's look shaper if the slide is reduced or enlarged as they are viewed in our on-line application. When I have used jpg or png they seem to break-up and don't seem as sharp if the viewing size is varied. I thought swf's were vector files as opposed to bitmapped graphics...am I wrong?
            THANKS again!!!! I'll give this a try
            mp
