0 Replies Latest reply on Sep 30, 2009 2:29 PM by Chet Haase
    [svn:fx-trunk] 10759: Fixes bug in transform effects on nested group structures.
    Chet Haase Level 3
      Revision: 10759
      Author:   chaase@adobe.com
      Date:     2009-09-30 13:29:28 -0700 (Wed, 30 Sep 2009)
      Log Message:
      Fixes bug in transform effects on nested group structures. We would calculate the transform center based on outdated width/height information for a group (because we took those values prior to running layout on the group, so it was not sized correctly).
      The fix is to add width/height to the list of properties that transform effects care about (?\226?\128?\152affectedProperties?\226?\128?\153). Then at those times when we calculate the transform center, we will use these cached values (which are correct at start/end time) rather than going out to the object to grab a potentially wrong value.
      QE notes:  Handful of Mustella tests fail due to the new values of relevantProperties/affectedProperties for transform effects. We now care about width/height properties, too.
      Doc notes: None
      Bugs: SDK-23346
      Reviewer: Jason
      Tests run: checkintests, Mustella spark/effects, mx/effects/Parallel, mx/effects/Sequence
      Is noteworthy for integration: Yes, downstream teams care about this bug
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-23346
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/AnimateTransform.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/Move.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/Move3D.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/Rotate.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/Rotate3D.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/Scale.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/Scale3D.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/supportClasses/AnimateTransfor mInstance.as
