1 Reply Latest reply on Oct 1, 2009 9:59 PM by ShardulSingh
    Hide slider thumb
    Dharmesh Chheda
      I am not able to hide the slider thumbs for a slider.
      Here is a sample of what I am doing
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml">
           <mx:Script>
              <![CDATA[
                  public function disableSlider():void{
                      salesSizeSlider.enabled=false;
                      salesSizeSlider.getThumbAt(0).visible=false;
                      salesSizeSlider.getThumbAt(1).visible=false;
          </mx:Script>
      <mx:HSlider id="salesSizeSlider"  x="10" y="83" width="190" allowTrackClick="false" liveDragging="true"
                          showDataTip="false"  labelOffset="-10" thumbCount="2"
                          minimum="0" maximum="200" values="[0,200]" />
      <mx:Button x="203" y="197" label="Disable Slider" click="disableSlider()"/>
      </mx:Application>
      The above application hides the thumbs .. but If i add
      this line as the first statement in the disableSlider() method, the sliders do not hide.
      salesSizeSlider.values=[1,90];
      Any idea why .. I always set the slider values based on data from backend and if the values are equal then I need to hide the thumbs..
      Dharmesh
        • 1. Re: Hide slider thumb
          ShardulSingh Level 3
          Pls find the solution for your problem.Let me know if you have any issue.
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" creationComplete="getDataFromYourBackend()">
               <mx:Script>
                  <![CDATA[
                      private var firstThumbValue : Number;
                      private var secondThumbValue : Number;
                      private function getDataFromYourBackend():void
                            //set the slider varibles here as per the backend value.It's simply for demonstration                   //  here.
                            firstThumbValue = 1;
                            secondThumbValue = 90;
                            if(firstThumbValue != secondThumbValue)
                                  //Do not write this line for the case when your values are equal i.e. inside else                         //block.
                                  salesSizeSlider.values=[firstThumbValue,secondThumbValue];
                            else
              </mx:Script>
          </mx:Application>
          with Regards,
          Shardul Singh Bartwal
