0 Replies Latest reply on Sep 30, 2009 4:16 PM by KronInt
    Audio recording in flex
    KronInt
      I don't know much about flex but i wrote a code that should record a voice...
      Can someone tell why this code doesn't work?
      This is code
      <mx:Application
      xmlns:mx="http://www.adobe.com/2006/mxml"
      layout="absolute"
      width="323"
      height="150"
      backgroundGradientAlphas="[1.0, 1.0]"
      backgroundGradientColors="[#f4f4f4, #cccccc]"
      creationComplete="init()">
      <mx:Style>
      .playStyle {icon: Embed(source="icons/play_grey.png");}
      .pauseStyle {icon: Embed(source="icons/pause_grey.png");}
      </mx:Style>
      <mx:Script>
      <![CDATA[
      import mx.controls.Alert;
      import flash.net.NetStream;
      private var myMic:Microphone;
      private var nc:NetConnection;
      private var ns:NetStream;
      private var recordingState:String = "idle";
      private var myDuration:Number = 0;
      private var myServer:String = null;
      private var mySoundFile:String = null;
      private var myTimer:Timer = null;
      private var playbackTimer:Timer = null;
      private var timeLimit:Number = 0;
      private function init():void {
      // Not yet connected to the server. Disable the buttons.
      record_btn.enabled = false;
      stop_btn.enabled = false;
      play_btn.enabled = false;
      myServer = Application.application.parameters.myServer;
      mySoundFile = Application.application.parameters.mySound;
      timeLimit = Application.application.parameters.timeLimit;
      initMic("0xcccccc");
      myTimer = new Timer(1000, timeLimit);
      myTimer.addEventListener("timer", timerHandler);
      timeText.text = "Recording time limit: " + createCountdown(0);
      record_btn.addEventListener(MouseEvent.CLICK, record_start);
      stop_btn.addEventListener(MouseEvent.CLICK, record_stop);
      play_btn.addEventListener(MouseEvent.CLICK, record_play);
      setupNC();
      addEventListener(Event.ENTER_FRAME, showMicLevel);
      myMic = Microphone.getMicrophone();
      myMic.setSilenceLevel(0);
      myMic.rate = 22;
      statusText.text = "connecting";
      private function setupNC():void{
      nc = new NetConnection();
      nc.addEventListener(NetStatusEvent.NET_STATUS, netStatus);
      nc.connect(myServer);
      private function netStatus(event:NetStatusEvent):void {
      switch (event.info.code){
      case "NetConnection.Connect.Success" :
      setStatus("Connected");
      ns = new NetStream(nc);
      ns.attachAudio(myMic);
      record_btn.enabled = true;
      stop_btn.enabled = true;
      play_btn.enabled = true;
      break;
      case "NetStream.Record.Start" :
      setStatus("recording...");
      break;
      case "NetStream.Record.Stop" :
      setStatus("stopped recording");
      break;
      case "NetStream.Buffer.Full" :
      setStatus("playing");
      break;
      case "NetStream.Play.Start" :
      setStatus ("buffering");
      break;
      case "NetStream.Seek.Notify" :
      setStatus("Seeking");
      break;
      case "NetStream.Play.Reset" :
      setStatus("pausing");
      break;
      case "NetStream.Play.Stop" :
      //setStatus("stopping");
      break;
      case "NetStream.Buffer.Flush" :
      //setStatus("flushing buffer");
      break;
      case "NetStream.Play.Complete" :
      setStatus("Playback complete");
      break;
      private function record_start(event:Event):void{
      initMic("0xff0000");
      ns.close();
      ns.addEventListener(NetStatusEvent.NET_STATUS, netStatus);
      ns.publish(mySoundFile, "record");
      recordingState = "recording";
      setPBstatus('recording');
      myTimer.start();
      private function record_stop(event:Event):void{
      switch (recordingState) {
      case "recording" :
      ns.close();
      myTimer.reset();
      timeText.text = createCountdown(0);
      break;
      setStatus("stopped");
      case "playing" :
      //Alert.show("Stopping now");
      ns.play(false);
      ns.close();
      playProgress.visible = false;
      micLevel.visible = true;
      break;
      recordingState = "idle";
      setPBstatus('ready');
      private function record_play(event:Event):void{
      switch(recordingState){
      case "idle" :
      play_btn.styleName = "pauseStyle";
      play_btn.label = "pause";
      playSound();
      break;
      case "playing" :
      recordingState = "paused";
      play_btn.styleName = "playStyle";
      play_btn.label = "play";
      ns.togglePause();
      break;
      case "paused" :
      recordingState = "playing";
      ns.togglePause();
      break;
      private function playSound():void{
      playProgress.visible = true;
      micLevel.visible = false;
      ns.close();
      setStatus("buffering");
      var myClient:Object = new Object();
      ns.bufferTime = 5;
      ns.client = myClient;
      myClient.onMetaData = function(myMeta:Object):void{
      myDuration = myMeta["duration"];
      playbackTimer = new Timer(1000, myDuration);
      playbackTimer.addEventListener("timer", playbackTimerHandler);
      timeText.text = createTime(0);
      playbackTimer.start();
      myClient.onPlayStatus = function(myPBstatus:Object):void{
      if(myPBstatus["code"] == "NetStream.Play.Complete"){
      playProgress.value = 0;
      ns.play(mySoundFile);
      public function playbackTimerHandler(event:TimerEvent):void {
      timeText.text = createTime(ns.time);
      playProgress.value = (ns.time / myDuration) * 10;
      //timeText.text = ns.time.toString();
      private function scanPosition():void {
      ns.play(false);
      //divide by 10 because the Slider values go from 0 - 10 and we want a value
      //between 0 - 1.0
      ns.seek (playProgress.value/10 * myDuration);
      private function showMicLevel(event:Event):void{
      switch (recordingState){
      case "recording" :
      micLevel.setProgress(myMic.activityLevel, 100);
      break;
      case "idle" :
      break;
      case "playing" :
      micLevel.setProgress(ns.time, myDuration);
      timeText.text = createCounter(ns.time);
      break;
      private function setPBstatus(msg:String):void{
      micLevel.label = msg;
      private function initMic(myColor:String):void{
      micLevel.setStyle("barColor", myColor);
      private function createCountdown(time:int):String{
      time = timeLimit - time;
      var myBuffer:String = "0";
      var currentMins:int = Math.floor(time/60);
      var currentSecs:int = (time - (currentMins*60));
      var mySecs:String = ((currentMins < 10) ? myBuffer + currentMins.toString(): currentMins.toString())
      + ((currentSecs < 10) ? myBuffer + currentSecs.toString(): currentSecs.toString());
      return mySecs;
      private function createCounter(time:int):String{
      return mySecs;
      private function createTime(time:int):String{
      //time = timeLimit - time;
      return mySecs;
      public function timerHandler(event:TimerEvent):void {
      if(myTimer.currentCount < timeLimit){
      timeText.text = createCountdown(myTimer.currentCount);
      } else {
      myTimer.reset();
      record_stop(null);
      private function setStatus(msg:String):void{
      statusText.text = msg;
      </mx:Script>
      <mx:Text id="statusText" text="" width="320" height="25" y="124" x="3" textAlign="center"/>
      <mx:Text id="timeText" text="00:00" width="323" height="23" y="109" x="0" textAlign="center"/>
      <mx:Text id="titleText" text="Audio Recorder" width="317" height="50" y="0" x="3" textAlign="center" color="#0000FF" fontSize="24" fontWeight="bold"/>
      <mx:ProgressBar x="0" y="36" mode="manual" id="micLevel" label="" labelPlacement="bottom" width="320" themeColor="#ff0000" fontSize="10" fontWeight="normal"/>
      <mx:ControlBar x="0" y="63" width="320" height="45" horizontalAlign="center">
      <mx:Button
      label="record"
      id="record_btn"
      width="75"
      borderColor="#F71F09"
      color="#009900"
      icon="@Embed(source='icons/record_grey.png')"
      <mx:Button
      label="stop"
      id="stop_btn"
      width="75"
      height="35"
      color="#009900"
      icon="@Embed(source='icons/stop_grey.png')"
      <mx:Button
      label="play"
      id="play_btn"
      width="75"
      borderColor="#1005F6"
      color="#009900"
      styleName="playStyle"
      </mx:ControlBar>
      <mx:HSlider change="scanPosition()" id="playProgress" showTrackHighlight="true" width="320" x="0" y="34" visible="false"/>
      <mx:Text id="versionText" text="v2009.1.22.03" width="320" height="15" y="134" x="3" textAlign="right" fontSize="8"/>
      </mx:Application>
