4 Replies Latest reply on Oct 1, 2009 6:13 AM by $Nith$
    Question on Access Control
    $Nith$ Level 4
      A very simple doubt,
      I have created a process and a Task manager endpoint.
      Now the process card appears for all users.
      How to give access only to certain peoples to see and open the process cards??
      Nith
        • 1. Re: Question on Access Control
          Jasmin Charbonneau Level 4
          In adminui, where you configured the endpoint, there is a security tab.
          You can specify the users that have access to the card from there.
          Jasmin
          • 2. Re: Question on Access Control
            $Nith$ Level 4
            Thanks Jasmin.
            But do you mean the last Grid/Table of the Security Tab?
            If so,
                 1. the table is initially empty but still i'm able to see the card from workspace.
                 2. Specify Run As is unchecked. Do i need to enable it?
                 3. Also I tried to add an user name (not my name) but still i'm able to access the card
            Can you guide me what to do?
            Nith
            • 3. Re: Question on Access Control
              Yes
              If so,
                    Make sure your users are not part of the Administrator group. They should only have Workspace User role.
                   No.
                   Again check the roles of the user you're using.
              Let me know,
              Jasmin
              • 4. Re: Question on Access Control
                $Nith$ Level 4
                You are correct,
                All the developers are given Super Admin previlleges.
                After updating the Role, it works properly.
                Thanks Jasmin
                Nith.
