4 Replies Latest reply on Oct 15, 2009 12:10 PM by pjv@gs
    RH7 - Custom WebHelp Pro skin custom "Print" button does NOT display in version published to RH Server 8
    pjv@gs Level 1
      I customized a WebHelp Pro skin using the Omega skin as the basis. Everything works fine except the Print button, which I added using the same Action as shown in the BeautifulVista skin's Print button.
      Local Version (C: drive)
      1. When I generate my help project and view it locally from my C: drive after I accept the warning about viewing locally, I see the Print button.
      2. However, it does NOT work.  I've attached a graphic that shows the local version and the skin dialog where I set up the action for the Print button.
      RH Server 8 version
      • When I view the same project after I publish it to the server, the Print button does NOT display.
      QUESTIONS ARE:
      How do I get the Print button to function properly (active printer dialog)?
      If it can't work until it is published that fine but then how do I get it display when I view from server?
