• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Export Japanense Language to Excel
New Here ,
Oct 01, 2009 Oct 01, 2009
What I have is a translation mechanism where I'm trying to export the language in a database to an excel document for easier end user translation. The excel doc is than imported back into the database using an SSIS package.
I am simply using the <cfcontent> and <cfheader> tags to export the page contents to the excel worksheet.
When the excel doc loads for the japanese the language characters aren't even close. I have tried using different charset attributes in the header tag to no avail. If I remove the content/header tags and display the text directly to the website output it appears fine. If I copy the text from the site into excel that works just as fine as well so it's not a missing language package in excel.
Any ideas?
TOPICS
Advanced techniques
Views
708
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
Can you provide us some example code that demonstrates your problem?
Adam
Votes
Translate
Translate
Report
Report
New Here ,
Actually, according to privacy contracts I've signed I can't really share anything code related about it. I can however summarize it a little bit better.
The output of the page is two column based, formated using html tables.
Column #1 consists of the English language
Column #2 consists of the Japanese language
<html>
<head>
<title>Page</title>
</head>
<body>
<table>
<cfloop>
<tr>
  <td>Column #1</td>
  <td>Column #2</td>
</tr>
</cfloop>
</table>
<body>
</html>
The data is called by invoking a coldfusion component that pulls the data from a sql db.
Of course to output this data to excel I have added two coldfusion lines of code at the top
<cfcontent type="application/msexcel">
<cfheader name="Content-Disposition" value="filename=filename.xls">
Votes
Translate
Translate
Report
Report
New Here ,
I solved this issue...
Updated the content to include the charset attribute rather than the header tag, easy enough. blah!
<cfcontent type="application/msxcel; charset="ISO-2022-jp">
Votes
Translate
Translate
Report
Report
LEGEND ,
Good that you fixed it.
Just a note re your comment about privacy contracts: I didnt mean to just slap your actual code in there; because that'll often have too many "moving parts" to be clear as to what is causing the problem.  Part of troubleshooting a problem should be to create a minimalist replicable case of the problem.  This process helps eliminate possible contributing factors that actually have been demonstrated not to contribute.
For an example, see my post on this other thread.
I only say this because not being able to see the code when one has an issue is usually quite a big blockage to sorting the issue out (not so in this case, obviously), and "confidentiality" is seldom actually a good reason to not present some steps to replicate the issue.
Adam
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
No problem at all, thank you for the insight and I will keep this in mind for future posts.
Votes
Translate
Translate
Report
Report
Resources
Documentation
