0 Replies Latest reply: Oct 1, 2009 2:34 PM by joelio123 RSS
    how to debug flash remoting?
    joelio123 Community Member
      Hi I am using -  flashremoting.jar 1.0.52502 on tomcat.
      I have a 3 year old application that is running on 1 server, it works fine there, the flash client can connect to the java tomcat server and call methods and all is well.
      We are trying to stand this application up on another server, and I cant get the flash remoting to work, the server side java methods never get called (I added logging to them).
      In the adobe troubleshooting it says to go to /gateway and you should get a blank page.
      The weird thing is on both the server that works and the server that doesnt work, if I go there in a browser I get:
      HTTP Status 404 - /flashservices/index.html
      This is the same for both servers. So im not sure what to try next. Im not an expert in flash my flash guy says the client gets:  "Error opening URL"
      The url in the flashvars looks good, the flashgateway.jar file is in the web-inf/lib folder , the frconfig.txt is in web-inf/classes
      my web.xml has this:
      <servlet>
              <servlet-name>FlashGatewayServlet</servlet-name>
              <display-name>Flash Remoting Servlet</display-name>
              <description>
                  Servlet-based plugin to Flash Remoting
              </description>
              <servlet-class>
                  flashgateway.controller.GatewayServlet
              </servlet-class>
              <load-on-startup>10</load-on-startup>
          </servlet>
      <servlet-mapping>
              <url-pattern>/gateway</url-pattern>
          </servlet-mapping>
      what can I check next, how can I troubleshoot this and figure out if its a client problem or a server problem, or somewhere in the middle?
      thanks
      Joel
