4 Replies Latest reply on Oct 1, 2009 3:21 PM by PrepressPro1
    Problem saving .ai file into a pdf
    Robotdesigner
      Hi, I've been saving .ai files into .pdf's forever without any problems but now I can't and I can't figure it out. I am working in CS4 with a CS4 file. Here is the error I am getting. Maybe its just been too long of a day.
      This is an Adobe® Illustrator® File that was saved without PDF Content. To Place or open this  le in other applications, it should be re-saved from
      Adobe Illustrator with the "Create PDF Compatible File" option turned on. Thisoption is in the Illustrator Native Format Options dialog box, which appears when saving an Adobe Illustrator  le using the Save As command.
      I can't find the 'This option is in the Illustrator Native Format Options dialog box, which appears when saving an Adobe Illustrator  le using the
      Save As command.'
      Help!
      thanks
