1 Reply Latest reply on Oct 2, 2009 8:50 PM by pixlor
    how can i disable alpha channel?(using fireworks 8)
    win173d
      because i want to make a simutrans pak(the png image)
      thx
        • 1. Re: how can i disable alpha channel?(using fireworks 8)
          pixlor Level 4
          If you are saving your .png file, then you get a file that has data in it specific to Fireworks. (It's allowed by the PNG specification.) This will have alpha channel information and layer information in it.
          If you want a "normal" .png image, then you want to export, not save. When you export, you have the choice between 32-bit (full color + alpha transparency), 24-bit (full color, no transparency, and 8-bit (indexed color, colors can be semi-transparent).
          I think what you want to do, then, is export your Fireworks document as a 24-bit .png. I like using File > Image Preview and selecting the image type and exporting from there.
