0 Replies Latest reply on Oct 2, 2009 8:34 AM by Chet Haase
    [svn:fx-trunk] 10806: Fixes div-by-zero bug.
    Chet Haase Level 3
      Revision: 10806
      Author:   chaase@adobe.com
      Date:     2009-10-02 07:34:25 -0700 (Fri, 02 Oct 2009)
      Log Message:
      Fixes div-by-zero bug. Some animation code made the wrong assumption that duration+repeatDelay would never be zero. It's perfectly valid to have zero-dur animations. This would cause incorrect calculations in the timing code, causing us to think that we were in some repetition cycle instead of actually having ended the current zero-dur Animation.
      Fix was to special-case the "if dur==0" situation.
      QE notes:  None
      Doc notes: None
      Bugs: SDK-21422
      Reviewer: Hans
      Tests run: checkintests, Mustella spark/effects
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-21422
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/animation/Animation.as
