4 Replies Latest reply on Oct 5, 2009 12:01 PM by FALCONSEYE_
    form layout
    FALCONSEYE_
      I am kind of confused as what type of layout to pick and it's performance.  So far, I have the following:
      <mx:Canvas x="3" y="3" width="1018" height="750" borderStyle="solid">
          <mx:Form id="masterBillingFormulas">
              <mx:Grid>
                  <mx:GridRow>
                      <mx:GridItem colSpan="5">
                           <mx:Image source="header.jpg" width="982" height="394" x="0" y="0" scaleContent="true"/>
                      </mx:GridItem>
                  </mx:GridRow>
                  <mx:GridRow height="40">
                  <mx:GridItem>
                     <mx:FormItem label="Property Code:">
                               <mx:ComboBox id="propertyCode" dataProvider="{qry_communites}" change="onCreationComplete()"   />
                       </mx:FormItem>
                  </mx:GridItem>
                  <mx:GridItem>
                      <mx:Spacer width="5"/>
                  </mx:GridItem>
                  <mx:GridItem>
                     <mx:FormItem label="Utility Type:">
                            <mx:ComboBox id="utilityType" dataProvider="{qry_utilityTypes}"  />
                     </mx:FormItem>
                  </mx:GridItem>
                  <mx:GridItem>
                  </mx:GridItem>
                  <mx:GridItem>
                    <mx:FormItem label="Active:">
                      <mx:ComboBox id="active">
                          <mx:dataProvider>
                              <mx:Array>
                                  <mx:Object label="Yes" />
                                  <mx:Object label="No" />
                              </mx:Array>
                          </mx:dataProvider>
                      </mx:ComboBox>
                    </mx:FormItem>
                     </mx:GridItem>
                  </mx:GridRow>
      </mx:Canvas>
      I need to nicely align the label, the input field (combox,textbox,etc. etc.) and the buttons. Should I keep doing this or switch to something else?
      thanks in advance.
        • 1. Re: form layout
          rgadiparthi
          you can do this forms,.
          • 2. Re: form layout
            FALCONSEYE_ Level 1
            If I use:
            It displays evertything like in vbox. I need to be able to put 3-4 form items in one row. Some other rows might have 2 or even 1 form item.
            • 3. Re: form layout
              flashharry! Level 1
              You can nest form items and set the direction property
              <FormItem direction="horizontal" paddingLeft="0">
                   <FormItem label="Label1"  direction="horizontal">
                        <ComboBox id="myComboBox" />
                        <CheckBox id="myChckBox" selected="false" />
                   </FormItem>
                   <FormItem label="Label2"  direction="horizontal">
                        <TextInput id="myTextInput" />
                   </FormItem>
              </FormItem>
              • 4. Re: form layout
                FALCONSEYE_ Level 1
                Thanks, I am getting closer. If only I could put the labels, text boxes, comboBoxes in a nice order.
