5 Replies Latest reply on Oct 2, 2009 3:21 PM by ShardulSingh
    how to display TitleWindow from main application
    Alex-SM Level 1
      I have two mxml files, file1.mxml (the main application) and file2.mxml (a TitleWindow).    How can I display file2.mxml from file1.mxml in an actionscript function?
      file1.mxml
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml">
      <mx:Script>
          <![CDATA[
                private function call_file2():void
                     // displaying file 2
      <mx:Button label="Enter" click="call_file2()"/>
      </mx:Application>
      file2.mxml
      <mx:TitleWindow xmlns:mx="http://www.adobe.com/2006/mxml">
      </mx:TitleWindow>
        • 1. Re: how to display TitleWindow from main application
          ShardulSingh Level 3
          Pls find the code for your function.If you have any issue with this pls let me know.
                  var myPopUp:file2= file2(PopUpManager.createPopUp(this, file2, true));
                   myPopUp.move(((Application.application.width/2)-(myPopUp.width/2)),
                   ((Application.application.height/2)-(myPopUp.height/2)));
          With Regards,
          Shardul Singh Bartwal
          • 2. Re: how to display TitleWindow from main application
                If you don’t want in the popup style then use the code below.
                        var myCustomComponent : file2 = new file2();
                        myCustomComponent.name = "myCustomComponent";
                        if(this.getChildByName("myCustomComponent") == null)
                            this.addChild(myCustomComponent);
                With Regards,
            • 3. Re: how to display TitleWindow from main application
              Alex-SM Level 1
              Thanks a lot. I chose the second. It works great.
              • 4. Re: how to display TitleWindow from main application
                Alex-SM Level 1
                There is one problem here.
                file2.mxml contains a ViewStack with two canvases. Each canves has a datagrid that are being filled with data from mysql database.
                Your suggetsion only create an empty page of file2.mxml, i.e. none of the actions defined in this file2.mxml works.
                what's a way to move from file1.mxml to file2.mxml (with all actions) and not just to display file2.mxml in file1.mxml?
                • 5. Re: how to display TitleWindow from main application
                  It will work fine If you will define your file2.mxml properly.You can relplace your file2.mxml code with the code below,and it will work fine.
                  Get the data from your backend where I m settting the dataprovider of the datagrids. You dont require to do any change in file1.mxml.
                  Replace the containt of file2.mxml with the code below.
                  file2.mxml
                        width="400" height="300" creationComplete="onCreationComplete()">
                        <mx:Script>
                  <![CDATA[
                        import mx.collections.ArrayCollection;
                        private var acDg1 : ArrayCollection = new ArrayCollection([
                        {Name:"Martin",Age:"21",Dept:"Dept1"},
                        {Name:"Devid",Age:"22",Dept:"Dept2"},
                        {Name:"Ali",Age:"23",Dept:"Dept3"}
                        private var acDg2 : ArrayCollection = new ArrayCollection([
                        {Name:"Jojo",Age:"31",Dept:"Dept11"},
                        {Name:"Cris",Age:"32",Dept:"Dept22"},
                        {Name:"Henry",Age:"33",Dept:"Dept33"}
                  private function onCreationComplete():void
                        dg1.dataProvider = acDg1;
                        dg2.dataProvider = acDg2;
                  private function switchCanvas():void
                        if(vstk.selectedIndex == 0)
                              vstk.selectedIndex = 1;
                        else
                              vstk.selectedIndex =0;
                  </mx:Script>
                  <mx:ViewStack id="vstk" width="100%" height="100%" creationPolicy="all">
                        <mx:Canvas id="can1">
                              <mx:VBox>
                                    <mx:Label text="First Canvas"/>
                                    <mx:DataGrid id="dg1">
                                    <mx:columns>
                                    <mx:DataGridColumn headerText="Name" dataField="Name"/>
                                    <mx:DataGridColumn headerText="Age" dataField="Age"/>
                                    <mx:DataGridColumn headerText="Dept" dataField="Dept"/>
                                    </mx:columns>
                                    </mx:DataGrid>
                              </mx:VBox>
                        </mx:Canvas>
                        <mx:Canvas id="can2">
                              <mx:VBox>
                                    <mx:Label text="Second Canvas"/>
                                    <mx:DataGrid id="dg2">
                                    <mx:columns>
                                    </mx:columns>
                                    </mx:DataGrid>
                              </mx:VBox>
                        </mx:Canvas>
                  </mx:ViewStack>
                  <mx:Button label="Change To Another Canvas" click="switchCanvas()"/>
                  </mx:TitleWindow>
                  with Regards,
