0 Replies Latest reply on Oct 2, 2009 11:29 AM by rfrishbe
    [svn:fx-trunk] 10826: When a Video is removed from the stage or becomes invisible, the video will now pause playback.
    rfrishbe Level 3
      Revision: 10826
      Author:   rfrishbe@adobe.com
      Date:     2009-10-02 10:28:43 -0700 (Fri, 02 Oct 2009)
      Log Message:
      When a Video is removed from the stage or becomes invisible, the video will now pause playback.  This features is controlled through a new property, playWhenHidden, which defaults to false (meaning we don't play the video when it's hidden).  When it becomes visible/on-stage again, we will start playing the video if autoPlay=true.  Otherwise, the video will not automatically start playback.
      This property still needs to be reviewed by PARB.
      Also, updating a comment in SkinnableContainer relating to a FIXME I own.
      QE notes: -
      Doc notes: -
      Bugs: SDK-21928
      Reviewer: Deepa
      Tests run: checkintests, mustella VideoElement/VideoPlayer
      Is noteworthy for integration: Yes
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-21928
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/SkinnableContainer.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/VideoPlayer.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/VideoElement.as
