0 Replies Latest reply on Oct 2, 2009 11:42 AM by Jason Szeto
    [svn:fx-trunk] 10828: FXG stroke and fill translation fix
    Jason Szeto Level 3
      Revision: 10828
      Author:   jszeto@adobe.com
      Date:     2009-10-02 10:41:48 -0700 (Fri, 02 Oct 2009)
      Log Message:
      http://bugs.adobe.com/jira/browse/SDK-23257 - Gradient translation should occur from 0,0, not the upper left bounds
      The current API only passes in the shape's bounds. I have added a new targetOrigin parameter to IFill.begin, IStroke.apply and IStroke.createGraphicsStroke of type Point. It is the origin (0,0) of the shape in the target graphic's coordinate space.
      Changed the logic in the gradient stroke and fills. The x and y transform properties are now positioned relative to the origin instead of to the top left corner of the bounds. If no x and y are set, then the default behavior remains the same.
      Removed the centering logic in LinearGradientStroke when scaleX was set.
      This API change has been approved by PARB.
      QE notes: Need to add tests that exercise this logic
      Doc notes: Need to document additions to the API
      Bugs: SDK-23257
      Reviewer: Deepa
      Tests run: spark/primitives, gumbo/components
      Is noteworthy for integration: Yes, modifications to the API
      Ticket Links:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/BitmapFill.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/GradientStroke.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/IFill.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/IStroke.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/LinearGradient.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/LinearGradientStroke.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/RadialGradient.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/RadialGradientStroke.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/SolidColor.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/SolidColorStroke.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/Line.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/Path.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/FilledElemen t.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/supportClasses/StrokedEleme nt.as
