11 Replies Latest reply on Dec 17, 2009 10:27 AM by jerryhamby
    Trying to get started with OSMF
    lisamarienyc
      I'm putting together a very basic example to get people started with OSMF, to demonstrate how to play a video and listen for some events, just in an AS3 class in Flash CS4. Having some trouble. I've referenced as many examples as I can find, and have come up with the following example which initializes, but then does nothing. No errors thrown.  I am a bit rusty, to be honest, so it's likely something simple... Any help or advice greatly appreciated. (also attached source)
      package {
      import flash.display.Sprite;
      import org.openvideoplayer.events.LoadableStateChangeEvent;
      import org.openvideoplayer.events.MediaPlayerCapabilityChangeEvent;
      import org.openvideoplayer.media.MediaPlayer;
      import org.openvideoplayer.media.URLResource;
      import org.openvideoplayer.net.NetLoader;
      import org.openvideoplayer.traits.ILoadable;
      import org.openvideoplayer.traits.LoadState;
      import org.openvideoplayer.traits.MediaTraitType;
      import org.openvideoplayer.video.VideoElement;
      import org.openvideoplayer.utils.URL;
      public class OSMFExampleTwo extends Sprite {
          private const PROGRESSIVE:String = "tyra-clip_1_VP6_768K.flv";
          private var _player:MediaPlayer;
          public function OSMFExampleTwo() {
              trace("initialized");
              _player = new MediaPlayer();
              _player.addEventListener( MediaPlayerCapabilityChangeEvent.VIEWABLE_CHANGE, onViewable );
              _player.source = new VideoElement( new NetLoader(), new URLResource(new URL(PROGRESSIVE)));
              var loadable:ILoadable = _player.source.getTrait( MediaTraitType.LOADABLE ) as ILoadable;
              loadable.addEventListener( LoadableStateChangeEvent.LOADABLE_STATE_CHANGE, onLoaded );
              private function onLoaded( e:LoadableStateChangeEvent ) :void {
                  if( e.newState == LoadState.LOADED ) {
                  trace( 'load completed' );
                  } else if( e.newState == LoadState.LOAD_FAILED ) {
                  trace( 'load failed' );
              private function onViewable( e:MediaPlayerCapabilityChangeEvent ) :void {
                  if( e.enabled ) {
                      addChild( _player.view );
                      trace('player view');
        • 1. Re: Trying to get started with OSMF
          Edwin van Rijkom
          Hi Lisa,
          Thanks for trying out the framework! I think the problem is with the local path that you are specifying. If I replace it by a fully qualified one like so:
          private const PROGRESSIVE:String = "file://localhost/Users/edwin/Downloads/osmfexample/tyra-clip_1_VP6_768K.flv";
          then things work. I see no reason why the load state change handler shouldn't be signaling 'LOAD_FAILED' though. It'd be great if you could log a bug on that at http://bugs.adobe.com/jira/ under the 'Strobe' project.
          Cheers,
          Edwin
          PS: the movie you included seems to be blank, audio only?
          • 2. Re: Trying to get started with OSMF
            RyanOConnell Level 2
            There is a bug with out relative path handling for URLs on the URLResource.  If you specify your video with a leading "./", like this  : "./tyra-clip_1_VP6_768K.flv"  it should load the video.  You could also use direct http:// or file:// style urls for local files.  Thanks for the feedback!
            Ryan O'Connell
            OSMF Engineering
            • 3. Re: Trying to get started with OSMF
              lisamarienyc Level 1
              Great! This does get a video to load, but its not autoplaying. Isn't that the default behavior?
              // Lisa
              • 4. Re: Trying to get started with OSMF
                Edwin van Rijkom Level 2
                Yes, that's the default behavior.
                It did automatically start playing just now when I tried your sample - but we might be on a different version of the framework (I was building from the trunk). If that's not the case, then it'd be great if you could log it as a bug!
                Cheers,
                Edwin
                • 5. Re: Trying to get started with OSMF
                  Actually, I'm now realizing that the sound is playing, but the video is just a black frame.
                  I'll log a bug.
                  Glad it's not me!
                  Thanks for the help.
                  // Lisa Larson-Kelley
                  • 6. Re: Trying to get started with OSMF
                    Ah - yes, I'd noticed that too - but I believe this is your FLV. If I play it back with VLC, example, it shows black too. Could you make sure it is not your FLV before you submit?
                    Thanks!
                    Edwin
                    • 7. Re: Trying to get started with OSMF
                      Yep. You're right. I tested a different video and it works fine. Hurrah!
                      Thank you!
                      • 8. Re: Trying to get started with OSMF
                        That's great to hear - thanks for letting us know!
                        Cheers,
                        Edwin
                        • 9. Re: Trying to get started with OSMF
                          jerryhamby
                          Is this bug fixed in Sprint 8? I'm using Sprint 7 and I can only get the first image to load and become visible.
                          Here are some tests I ran:
                          ====== this works, and I can view every image one at a time, this is NOT a slideshow  =======
                          pImageSerialElement = new SerialElement();
                          pImageSerialElement.addChild(new ImageElement(new ImageLoader(),new URLResource(new URL("images/image4.jpg"))));
                          pImageSerialElement.addChild(new ImageElement(new ImageLoader(),new URLResource(new URL("images/image2.png"))));
                          pImageSerialElement.addChild(new ImageElement(new ImageLoader(),new URLResource(new URL("images/image3.png"))));
                          ====== this works a little    image1=loaded, image2=loadFailed,  image3=loadFailed =======
                          pImageSerialElement.addChild(new TemporalProxyElement(3, new ImageElement(new ImageLoader(), new URLResource(new URL("images/image4.jpg")))));
                          pImageSerialElement.addChild(new TemporalProxyElement(3, new ImageElement(new ImageLoader(), new URLResource(new URL("images/image2.jpg")))));
                          pImageSerialElement.addChild(new TemporalProxyElement(3, new ImageElement(new ImageLoader(), new URLResource(new URL("images/image3.jpg")))));
                          ====== does not work at all   image1= loadFailed, image2=loadFailed,  image3=loadFailed  =======
                          ====== TemporalProxyElement =======
                          ... new URLResource(new URL("/images/image4.jpg")))));
                          … new URLResource(new URL("/images/image2.jpg")))));
                          … new URLResource(new URL("/images/image3.jpg")))));
                          ... new URLResource(new URL("./images/image4.jpg")))));
                          … new URLResource(new URL("./images/image2.jpg")))));
                          … new URLResource(new URL("./images/image3.jpg")))))
                          ... new URLResource(new URL("../images/image4.jpg")))));
                          … new URLResource(new URL("../images/image2.jpg")))));
                          … new URLResource(new URL("../images/image3.jpg")))))
                          ====== does not work at all  image1= loadFailed, image2=loadFailed,  image3=loadFailed  ======= I'm on a Mac
                          … new URLResource(new URL("MacProTera/OSMF/Version5/images/image4.jpg")))));
                          … new URLResource(new URL("MacProTera/OSMF/Version5/images/image2.jpg")))));
                          … new URLResource(new URL("MacProTera/OSMF/Version5/images/image3.jpg")))));
                          ====== this works a little,image1=loaded, image2=loadFailed,  image3=loadFailed ======= I'm on a Mac
                          … new URLResource(new URL("MacProTera:OSMF:Version5:images:image4.jpg")))));
                          ... new URLResource(new URL("MacProTera:OSMF:Version5:images:image2.jpg")))));
                          … new URLResource(new URL("MacProTera:OSMF:Version5:images:image3.jpg")))));
                          • 10. Re: Trying to get started with OSMF
                            bringrags Level 4
                            The first two cases work fine for me.  Is it possible you have the wrong URL in the second example?  I noticed that the extension is PNG in the first case, and JPG in the second.
                            • 11. Re: Trying to get started with OSMF
                              jerryhamby Level 1
                              Good catch, it was the naming problem. The nasty copy/paste strikes again!
