0 Replies Latest reply on Oct 2, 2009 4:59 PM by GordonSmith
    [svn:fx-trunk] 10848: Removed the [ExcludeClass] metadata on the out-of-package class FTETextFieldStyleResolver in TLFTextField .as.
    GordonSmith Level 4
      Revision: 10848
      Author:   gosmith@adobe.com
      Date:     2009-10-02 15:59:52 -0700 (Fri, 02 Oct 2009)
      Log Message:
      Removed the metadata on the out-of-package class FTETextFieldStyleResolver in TLFTextField.as. It was actually causing TLFTextField to be excluded, and is not necessary on an out-of-package class, which is invisible except to code in the same file.
      QE notes: None
      Doc notes: None
      Bugs: None
      Reviewer: Carol
      Tests run: ant checkintests
      Is noteworthy for integration: No
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/mx/core/TLFTextField.as
