17 Replies Latest reply on Oct 7, 2009 4:03 AM by Tareq_1993
    NaN
    Tareq_1993 Level 1
      Hello mates
      In Action Script 2,
      When I type any maths formula (subtraction / tan / ^2) I always get the result NaN (Not a Number)
      How can I resolve it?
      e.g on(release) = {south - west}
      and I enter number 5 in south and 6 in west.
      I get the result, NaN.
      same when I try on(release) {result = Math.atan2(Fy,Fx)}
      (I already named the input boxes as Fy Fx and result)
      but I get the answer in dynamic box NaN.
      How can I resolve that, and get number instead of Tan?
      thx alot.
        • 1. Re: NaN
          Saransoft84 Level 3
          Try this piece of code:
          on(release) {
          result = Math.atan2(Number(_root.Fy.text),Number(_root.Fx.text));
          trace(result);
          Saransoft
          • 2. Re: NaN
            As the previous response to your posting shows, when you are usng textfields, to get the content from them you need to access the text property of them... Fy.text, Fx.text... etc  And when you use those values in equations, it is safest to use the Number() function to convert them from string to number values... sometimes not doing so will still workin AS2, but it is safest to be sure and to get into the practice of doing because in AS3 it doesn't.
            • 3. Re: NaN
              Rothrock Level 5
              Actually the safest way is to use parseInt() or parseFloat() those are the actual functions that convert text to numbers.
              Casting as a Number() doesn't actually convert the value and there are (rare) times when I have seen it fail.
              • 4. Re: NaN
                Tareq_1993 Level 1
                hey mate
                Thx for answering me, But I am afraid it didn't work.
                Original script was. On(release) {NS = North - South}
                After u said this, I wrote: on(release) {NS = parseFloat(North) - parseFloat(south)}
                But it still give NaN. So, mind giving me a written script? I am afraid I made a mistake or so.
                Thank you alot.
                • 5. Re: NaN
                  Tareq_1993 Level 1
                  hey mate
                  Thanks for helping me, but I am still beginner in flash, not expert in writing codes.
                  All I want, I have 4 input boxes, North, East, South and West.
                  I wanna subtract North - South and East - West.
                  tried on(release) { NS = North - South}
                  But I got in the dynamic box NaN.
                  Can you write me the full code plz?
                  I really appreciate it.
                  Thanks alot
                  • 6. Re: NaN
                    Tareq_1993 Level 1
                    hey mate
                    Thanks alot
                    • 7. Re: NaN
                      clbeech Level 3
                      the previous posts here have given you the answer   - when attempting to access the value within the TextField, you must target the 'text' property of the field - you are closest in the response to RRs post using parseFloat - however you did not target the 'text' property, so ...
                      on(release) {
                        var NS = parseFloat(North.text) - parseFloat(South.text);
                      OR
                      on(release) {
                        var NS = Math.atan2(parseFloat(Fy.text), parseFloat(Fx.text));
                      REM: atan2 will return a value in Radians
                      also - it 'may' be necessary to target _root or _parent as used above as well - it will depend on your structure.
                      additionally - it is a 'best practice' *not* to use 'Object attachment' methods (eg. the placement of code 'on' a MC object - using the on() handler in this manner)  instead one should place all code on the timeline or within class files - if placed on the timeline the correct code would be:
                      var NS:Number;
                      [btnInstanceName].onRelease = function() {
                      • 8. Re: NaN
                        Tareq_1993 Level 1
                        hey matey
                        I tried everyone of ur scripts, still getting NaN.
                        Can u make a flash document, insert 4 input text boxes and 2 dynamic, and write the scripts, on either button or timeline, and send me it (*fla)?
                        cuz IDK whats problem with my flash.
                        plz after u make it send to Car_orange@hotmail.com
                        or upload it to www.4shared.com and put link here.
                        I appreciate it.
                        thx alot
                        • 9. Re: NaN
                          Rothrock Level 5
                          A couple more things to check. Look to see if the auto kern box is checked on your text fields. Make sure it is off.
                          Also add the following trace statements:
                          trace("South is: ["+South.text+"]);
                          trace("South parsed is: "+parseFloat(South.text,10));
                          What do those trace?
                          • 10. Re: NaN
                            Tareq_1993 Level 1
                            hey mate
                            I checked the auto Kern, and yea, it was on, so I changed it to off.
                            And about the second thing, after I typed it I got:
                            **Error** Scene=Scene 1, layer=Layer 1, frame=1:Line 3: String literal was not properly terminated
                            **Error** Scene=Scene 1, layer=Layer 1, frame=1:Line 5: ')' or ',' expected
                            **Error** Scene=Scene 1, layer=Layer 1, frame=1:Line 3: Statement must appear within on handler
                            Total ActionScript Errors: 3      Reported Errors: 3
                            thanks alot.
                            • 11. Re: NaN
                              You're missing onew quotation mark at the end...
                              trace("South is: ["+South.text+"]");
                              • 12. Re: NaN
                                Tareq_1993 Level 1
                                **Error** Scene=Scene 1, layer=Layer 1, frame=1:Line 2: Statement must appear within on handler
                                **Error** Scene=Scene 1, layer=Layer 1, frame=1:Line 4: Statement must appear within on handler
                                Total ActionScript Errors: 2      Reported Errors: 2
                                Yea mate, thx alot, actually 1 problem solved, still got 3 to go...
                                Can you write me the full code?
                                on(release) {NS = North - South}
                                thats what I know, can u continue the rest about tracing and so?
                                thx alot.
                                • 13. Re: NaN
                                  clbeech Level 3
                                  those 'trace' statements need to be placed within the on(release) handler
                                  • 14. Re: NaN
                                    Tareq_1993 Level 1
                                    hey matey
                                    I wrote:
                                    on(release) {NS = Number(North) - Number(south)
                                    But I got NaN, and this:
                                    South is: [undefined]
                                    South parsed is: NaN
                                    So how cna we resolve this?
                                    thx alot.
                                    • 15. Re: NaN
                                      Tareq_1993 Level 1
                                      aww mates, no answer?
                                      I really need help with that >_<
                                      thx anyway
                                      • 16. Re: NaN
                                        Rothrock Level 5
                                        Well that part isn't going to work, because you aren't accessing the text properties.
                                        This trace("South is: ["+South.text+"]"); is telling you that there is no South.text property. Capitalization matters. Does this code match what is on your stage?
                                        What if you add a trace like this:
                                        trace("Current scope is: "+this);
                                        trace("Found south: "+south);
                                        What do you get for those?
                                        The choices pretty much are:
                                        There is a spelling or capitalization error.
                                        The input field south (or South) does not exist at all when the button is pressed.
                                        The input field is in some other timeline that is not being properly referenced.
                                        There is some other local variable named south that exists, but is undefined.
                                        So we just have to figure out which of those it is. You can also try the same traces with north or North or what ever it is. Are they the same?
                                        • 17. Re: NaN
                                          Tareq_1993 Level 1
                                          Its ok mate.
                                          I was getting Nan, cuz we were only tracing South, I tried to trace north, too, and it worked. Now no NaN anymore. You gonna get the 10 points for correct answer, and everyone tried to answer is thanked for faithful help, he will get 5 points for helpful answer.
                                          1 more thing, I need.
                                          TF = (NS)^2 x (EW)^2
                                          how can we write that code? (TF is the result)
