0 Replies Latest reply on Oct 2, 2009 11:48 PM by raikprashant
    Script for replacing Image from a frame into InDesign document file
    raikprashant
      Hi All,
      I am having an indesign document (indd) file with images and texts. I am using InDesign Server CS4 to run the scripts via SOAP.
      My requirement is to replace any of the images from the required frame/s of indesign document through scripting (I already have frame id of which image needs to be replaced). I have written written java-script file (as given below): but when I execute this java-script on InDesign Server via SOAP, I get follwoing error into InDesign Server:
      10/03/09 15:15:54 INFO  [javascript] Executing File: \\Server_IP_Address\JavaScript_File_Path\JavaScript_File.js
      10/03/09 15:16:01 ERROR [link manager] Link missing.; file:C:/help.gif
      10/03/09 15:16:01 ERROR [link manager] Link missing.; file:C:/Documents%20and%20Settings/All%20Users/Documents/My%20Pictures/Sample%20Pictures/ Water%20lilies.jpg
      10/03/09 15:16:01 ERROR [link manager] Link missing.; file:C:/Documents%20and%20Settings/All%20Users/Documents/My%20Pictures/Sample%20Pictures/ Winter.jpg
      Following is the java-script that is being used for replacing image from indd's frame:
      var myDocument = app.open(File('//Server_IP_Address/InDesignDocument_File_Path/Sample.indd'));
      var tmp_frmid="1339"; //frame id of which image needs to be replaced.
      for (var i=0;i<myDocument.pages.length;i++)
      var objPage=myDocument.pages.item(i);
      var objPageitems = objPage.pageItems;
      try
      var obj = objPageitems.itemByID(tmp_frmid);
      obj.images[0].remove;
      obj.appliedObjectStyle = null;
      var myImage=obj.place(File('//
      Server_IP_Address/Images_to_be_reolaced_Path/ImageFile.jpg'));
      var old_height = myImage.geometricBounds[2] - myImage.geometricBounds[0];
      var new_height = obj.geometricBounds[2] - obj.geometricBounds[0];
      var old_width = myImage.geometricBounds[3] - myImage.geometricBounds[1];
      var new_width = obj.geometricBounds[1] + ((new_height / old_height) * old_width);
      myImage.geometricBounds = [obj.geometricBounds[0] + "mm", obj.geometricBounds[1] + "mm", obj.geometricBounds[2] + "mm", new_width + "mm"];
      var diff = obj.geometricBounds[1] - myImage.geometricBounds[1];
      myImage.move( undefined, [diff,0] );
      break;
      catch(e)
      myDocument.save('//
      Server_IP_Address/InDesignDocument_File_Path/Sample.indd');
      var previewFile = File('//
      Server_IP_Address/Images_to_be_reolaced_Path/ImageFile.jpg');
      app.jpegExportPreferences.jpegQuality["JPEGOptionsQuality.low"];
      app.documents.item(0).exportFile(ExportFormat.jpg, previewFile);
      myDocument.close();
      I have very urgent requirement; if anyone have any idea; please suggest me. \
      It would be highly appreciable.
      Kind Regards,
      Prashant.
