2 Replies Latest reply on Oct 4, 2009 3:49 AM by neil.sonaron
    Help on updateDisplayList sequence calls
    neil.sonaron
      Hi all,
      I'm currently working on the Callout code (from this adobe example http://www.adobe.com/devnet/flex/samples/fig_callout/).
      The code contains two AS classes CalloutContainer.as and CalloutBorder.as. Second class is a programatically border used to render the CalloutContainer.
      I'm using these classes in a project with ModestMaps library (to work with maps like GoogleMaps Flash API). The problem is the first time the Callout is rendered all is fine but if I move the map the Callout is not right positioned.
      I have debugged the code and seems the first time the Callout is rendered both CalloutContain.updateDisplayList and CalloutBorder.updateDisplayList (in that order) are invoqued. Next when I move the map only ColloutBordr.updateDisplayList is invoqued. What I need is to execute CallouytContaine.updateDisplayList always before CalloutBorder.updateDisplayList.
      I hope to explain more or less well so you can understand me (sorry for my poor english).
      What I need is some explanation (or references to some docs) about programatically border classes or how updateDisplayList methods are called.
      Thanks in advice.
