1. Re: Anyone else getting adobe AIR error 2032 when trying to download Adobe max companion?
pwillener Oct 4, 2009 7:35 PM (in response to the_missing_link)Is this a Flash Player issue? If so, please clarify how.
I think this is related to Adobe AIR, which has its own forum at http://forums.adobe.com/community/air.
2. Re: Anyone else getting adobe AIR error 2032 when trying to download Adobe max companion?
the_missing_link Oct 4, 2009 9:53 PM (in response to pwillener)Thank you for responding. I found the problem. No it isn't a flash player
issue it is an AIR issue. I didn't know there was an AIR forum. I will post
the answer here instead of duplicating posts. If you are a developer and
have a virtual server on your computer you most likely will run into the AIR
error 2032 when trying to download the MAX companion for the conference
starting tommorow-Wednesday (Monday-Wednesday). You need to either add in a
chunk of code to your server that allows AIR to run or use a different
computer. I used a different computer but I read that someone found the
solution to this error is to add the code to their virtual server. I use
XAMPP, which is a rather popular Virtual Server. Okay well I hope this helps
anyone in the future.
3. Re: Anyone else getting adobe AIR error 2032 when trying to download Adobe max companion?
pwillener Oct 4, 2009 10:04 PM (in response to the_missing_link)Thank you for the feedback. I will ask a moderator to move the topic to the appropriate forum, so that other users can easily find your information.
4. Re: Anyone else getting adobe AIR error 2032 when trying to download Adobe max companion?
the_missing_link Oct 4, 2009 10:19 PM (in response to pwillener)Your welcome. I also just discovered that if you can save the file and than
e-mail it to yourself, than open the e-mail on the computer that couldn't
download it from the internet it will work. I know it is a very odd solution
but I'm using Windows Vista so everything is a bit odd.
5. Re: Anyone else getting adobe AIR error 2032 when trying to download Adobe max companion?
Captiv8r Oct 6, 2009 4:53 AM (in response to the_missing_link)This thread has been moved to the Adobe AIR forum at the request of a thread participant.
