1 Reply Latest reply on Oct 8, 2009 11:21 PM by Pari Semarang
    Problem while installing account enrollment template
    Pari Semarang
           Hello,
           I've benn facing a serious problem for a week while installing account enrollment template.
           System Environment is like this:
                -     Windows Server 2003 Enterprise Edition
                -     Microsoft SQL Server 2005 SP2
                -     IBM Websphere Application Server 6.1.7
           LiveCycle ES 8.2 works fine.
           But installing account enrollment template is failure. Error message is as follow;
      //------------------------------------------------------- Begin -------------------------------------------------
      C:\sas\account_enrollment_1_0\sa\building_blocks\snc_1_0\install>ant pre-deploy-
      invoker
      Buildfile: build.xml
      pre-deploy-invoker:
          [unzip] Expanding: C:\sas\account_enrollment_1_0\sa\building_blocks\snc_1_0\
      dist\webapp\adobe-bb-snc-invoker.ear into C:\sas\account_enrollment_1_0\sa\build
      ing_blocks\snc_1_0\build\invoker\pre-deploy
          [mkdir] Created dir: C:\sas\account_enrollment_1_0\sa\building_blocks\snc_1_
      0\build\invoker\pre-deploy\war
      build\invoker\pre-deploy\invoker.war into C:\sas\account_enrollment_1_0\sa\build
      ing_blocks\snc_1_0\build\invoker\pre-deploy\war
      [propertyfile] Updating property file: C:\sas\account_enrollment_1_0\sa\building
      _blocks\snc_1_0\build\invoker\pre-deploy\war\WEB-INF\classes\messages.properties
         [delete] Deleting: C:\sas\account_enrollment_1_0\sa\building_blocks\snc_1_0\b
            [zip] Building zip: C:\sas\account_enrollment_1_0\sa\building_blocks\snc_1
      _0\build\invoker\pre-deploy\invoker.war
         [delete] Deleting directory C:\sas\account_enrollment_1_0\sa\building_blocks\
         [delete] Deleting: C:\sas\account_enrollment_1_0\sa\building_blocks\snc_1_0\d
      _0\dist\webapp\adobe-bb-snc-invoker.ear
      BUILD SUCCESSFUL
      Total time: 2 seconds
      C:\sas\account_enrollment_1_0\sa\building_blocks\snc_1_0\install>ant call-deploy
      er -Ddeployer.targets=import-data -Dconfig.beans.path=c:\sas\account_enrollment_
      1_0\sa\building_blocks\snc_1_0/snc_portal/sample/resource/adobe-bb-snc-samplecon
      fig-beans.xml -Dbundle.dir=c:\sas\account_enrollment_1_0\sa\building_blocks\snc_
      1_0/snc_portal/sample/resource/bundles
      call-deployer:
           [echo] Basedir is C:\sas\account_enrollment_1_0\sa\building_blocks\snc_1_0\
      deployer
           [echo] hostname is: LIVECYCLE
           [echo] Tools Found: C:\sas\account_enrollment_1_0\sa\building_blocks\snc_1_
      0\deployer/../tools
      import-data:
      BUILD FAILED
      C:\sas\account_enrollment_1_0\sa\building_blocks\snc_1_0\install\build.xml:121:
      The following error occurred while executing this line:
      C:\sas\account_enrollment_1_0\sa\building_blocks\snc_1_0\install\build.xml:123:
      C:\sas\account_enrollment_1_0\sa\building_blocks\snc_1_0\deployer\build.xml:140:
      Warning: Could not find file c:\sas\account_enrollment_1_0\sa\building_blocks\s
      nc_1_0\snc_portal\sample\resource\adobe-bb-snc-sampleconfig-beans.xml to copy.
      Total time: 0 seconds
      call-deployer:
      deployer
      0\deployer/../tools
      import-data:
           [copy] Copying 1 file to C:\sas\account_enrollment_1_0\sa\building_blocks\s
      nc_1_0\dist\deployer
           [java] Oct 5, 2009 6:39:52 PM org.springframework.beans.factory.xml.XmlBean
      DefinitionReader loadBeanDefinitions
           [java] INFO: Loading XML bean definitions from file [C:\sas\account_enrollm
      ent_1_0\sa\building_blocks\snc_1_0\deployer\..\dist\deployer\config-beans.tmp.xm
      l]
           [java] Loading Global Settings...
           [java] ALC-DSC-012-000: com.adobe.idp.dsc.registry.ServiceNotFoundException
      : Service: ConfigurationRegistryService not found.
           [java]     at com.adobe.solutions.snc.ConfigurationRegistryServiceClient.ge
      tConfigurationSettingByName(ConfigurationRegistryServiceClient.java:75)
           [java]     at com.adobe.solutions.snc.utils.SpringDataImporter.handleGlobal
      Setting(SpringDataImporter.java:334)
           [java]     at com.adobe.solutions.snc.utils.SpringDataImporter.importData(S
      pringDataImporter.java:87)
           [java]     at com.adobe.solutions.snc.utils.SpringDataImporter.main(SpringD
      ataImporter.java:74)
           [java] Caused by: ALC-DSC-012-000: com.adobe.idp.dsc.registry.ServiceNotFou
      ndException: Service: ConfigurationRegistryService not found.
           [java]     at com.adobe.idp.dsc.registry.service.impl.ServiceRegistryImpl.g
      etService(ServiceRegistryImpl.java:1084)
      etHeadActiveConfiguration(ServiceRegistryImpl.java:935)
           [java]     at com.adobe.idp.dsc.engine.impl.ServiceEngineImpl.resolveConfig
      uration(ServiceEngineImpl.java:148)
           [java]     at com.adobe.idp.dsc.provider.impl.soap.axis.sdk.SoapSdkEndpoint
      .invokeCall(SoapSdkEndpoint.java:119)
      .invoke(SoapSdkEndpoint.java:81)
           [java]     at sun.reflect.GeneratedMethodAccessor532.invoke(Unknown Source)
           [java]     at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMet
      hodAccessorImpl.java:43)
           [java]     at java.lang.reflect.Method.invoke(Method.java:615)
           [java]     at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCPr
      ovider.java:397)
           [java]     at org.apache.axis.providers.java.RPCProvider.processMessage(RPC
      Provider.java:186)
           [java]     at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvid
      er.java:323)
           [java]     at org.apache.axis.strategies.InvocationStrategy.visit(Invocatio
      nStrategy.java:32)
           [java]     at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
           [java]     at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
           [java]     at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService.
      java:454)
           [java]     at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281)
           [java]     at org.apache.axis.transport.http.AxisServlet.doPost(AxisServlet
      .java:699)
           [java]     at javax.servlet.http.HttpServlet.service(HttpServlet.java:763)
           [java]     at org.apache.axis.transport.http.AxisServletBase.service(AxisSe
      rvletBase.java:327)
           [java]     at javax.servlet.http.HttpServlet.service(HttpServlet.java:856)
           [java]     at com.ibm.ws.webcontainer.servlet.ServletWrapper.service(Servle
      tWrapper.java:989)
      tWrapper.java:930)
           [java]     at com.ibm.ws.webcontainer.filter.WebAppFilterChain.doFilter(Web
      AppFilterChain.java:145)
           [java]     at com.adobe.idp.dsc.provider.impl.soap.axis.InvocationFilter.do
      Filter(InvocationFilter.java:43)
           [java]     at com.ibm.ws.webcontainer.filter.FilterInstanceWrapper.doFilter
      (FilterInstanceWrapper.java:190)
      AppFilterChain.java:130)
           [java]     at com.ibm.ws.webcontainer.filter.WebAppFilterChain._doFilter(We
      bAppFilterChain.java:87)
           [java]     at com.ibm.ws.webcontainer.filter.WebAppFilterManager.doFilter(W
      ebAppFilterManager.java:761)
      ebAppFilterManager.java:673)
           [java]     at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(
      ServletWrapper.java:498)
           [java]     at com.ibm.ws.wswebcontainer.servlet.ServletWrapper.handleReques
      t(ServletWrapper.java:464)
           [java]     at com.ibm.ws.webcontainer.servlet.CacheServletWrapper.handleReq
      uest(CacheServletWrapper.java:90)
           [java]     at com.ibm.ws.webcontainer.WebContainer.handleRequest(WebContain
      er.java:744)
           [java]     at com.ibm.ws.wswebcontainer.WebContainer.handleRequest(WebConta
      iner.java:1433)
           [java]     at com.ibm.ws.webcontainer.channel.WCChannelLink.ready(WCChannel
      Link.java:111)
           [java]     at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleDi
      scrimination(HttpInboundLink.java:454)
           [java]     at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleNe
      wInformation(HttpInboundLink.java:383)
           [java]     at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.ready(Ht
      tpInboundLink.java:263)
           [java]     at com.ibm.ws.tcp.channel.impl.NewConnectionInitialReadCallback.
      sendToDiscriminators(NewConnectionInitialReadCallback.java:214)
      complete(NewConnectionInitialReadCallback.java:113)
           [java]     at com.ibm.ws.tcp.channel.impl.AioReadCompletionListener.futureC
      ompleted(AioReadCompletionListener.java:165)
           [java]     at com.ibm.io.async.AbstractAsyncFuture.invokeCallback(AbstractA
      syncFuture.java:217)
           [java]     at com.ibm.io.async.AsyncChannelFuture.fireCompletionActions(Asy
      ncChannelFuture.java:161)
           [java]     at com.ibm.io.async.AsyncFuture.completed(AsyncFuture.java:136)
           [java]     at com.ibm.io.async.ResultHandler.complete(ResultHandler.java:19
      5)
           [java]     at com.ibm.io.async.ResultHandler.runEventProcessingLoop(ResultH
      andler.java:743)
           [java]     at com.ibm.io.async.ResultHandler$2.run(ResultHandler.java:873)
           [java]     at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1469)
      ist\deployer\config-beans.tmp.xml
      BUILD SUCCESSFUL
      Total time: 3 seconds
      //------------------------------------------------------- End ----------------------------------------------------
           I followed the getting started document, but I can not access the selection and capture sample portal.
           http://livecycle:9080/adobe-bb-snc-portal
           Does anyone have the solution or experience?
           Any help will be much appreciated. Now I'm hanging over.
           Thank you. (PS. I attached the configuration files.)
