4 Replies Latest reply on Oct 8, 2009 11:24 AM by radek.r
    send form. data from standalone pdf to LC Forms
    radek.r Level 1
      Hello,
      I am new in Adobe LC ES platform and would like to ask for advice with following.
      I need to provide user with a standalone pdf form, user should then be able to fill the form and send it to LiveCycle Forms server.
      I originally thought that easiest way to implement it is via SOAP, but I have not been able to make some working HelloWorld example. I have red some articles that suggests some workarounds (pdf form -> webserver -> SOAP to LC server; or to use coldFusion).
      Is there any tutorial or example which would describe posting of form to LiveCycle forms, when not using LC Workspace (not over mail or watched folders) ? Or what way would you suggest to deal with this ?
      Do I need reader-enable form to make SOAP call to store form data by Reader?
      Thanks.
        • 1. Re: send form. data from standalone pdf to LC Forms
          pguerett Level 6
          To make a soap call from Reader you will have to Reader Extend the form (using LiveCycle Server only). You can post the data to a servlet without Reader Extended and the servlet can interact with the Forms API to validate the data. I believe there is a sample on the DevNet site (look for articles written by Mike Hodgson). I am on a phone now so I do not have access to that content.
          Paul
          • 2. Re: send form. data from standalone pdf to LC Forms
            radek.r Level 1
            Thanks Paul,
            I am going to search DevNet. I recently found article (http://livecycleapps.wordpress.com/2009/01/16/submitting-pdf-form-data-over-the-internet-v ia-http/) which mentiones :
            If you are an Adobe LiveCycle Forms customer you can use the FormsService > processFormSubmission activity to process submitted data.
            That would be nice way, I have no strong experience with server side java, so I would prefer something without writting servlets. Do You have any experience with this method ?
            • 3. Re: send form. data from standalone pdf to LC Forms
              pguerett Level 6
              I am not a programmer but you will need to use  some sort of server side program to make that call. It can be exposed through SOAP as well.
              Paul
              • 4. Re: send form. data from standalone pdf to LC Forms
                radek.r Level 1
                It looks, that using web services may be after all most suitable for task needs.
                Perhaps last problem I have is to properly bind pdf form  to a process variable.
                I need to send pdf form to some livecycle process, which would store form entries to database. I am trying it in this way:
                - as a process start poin is defined [Set Value] service with execute action.
                - there is defined input, process, required variable "form" of type xfaForm with associated template-url pointing to mentioned .pdf form
                - in [Set Value] service it is only asserted some parts of "form" variable to another process variables
                tests:
                If I run process via wokbench (right-click on swim line + ivoke process), it returns job-id and values are stored in db (internal adobe table created for this process). But if I send (soaps) directly the pdf form and sniff the response packet, there is :
                <faultstring>
                The input BLOB object should have attachmentID, remoteURL, or binaryData field specified.
                </faultstring>
                ... and nothing is stored to db.
                Am I doing wrong mapping (wrong variable type? wrong assertion? ) or is this way bad completely.
                I have searched some article about the process side of WS binding, but haven't found nothing for LC 8.2.
                Thanks for advice.
