7 Replies Latest reply on Oct 12, 2009 8:05 AM by reedkm_unc
    [JS][CS3]Applying Character Style to First Word
    reedkm_unc
      I am a noob as far as Javascript  is concerned, and I was hoping for a little guidance.
      Here's my scenario: I have a book that has been typeset all in one file; the main content is all in one story. I want to select the first word of every text frame on each page and apply a character style. My goal is to utilize this character style to indicate page breaks in the XML--I'll map the style to a specific tag.
      So far I have this poor specimen:
      var myDocument = app.activeDocument;
      var myPage = myDocument.pages.item(1);
      var myTextFrame = myPage.textFrames.item(0);
      if( app.activeDocument.stories[0].paragraphs[0].words[0] != null )
      myTextFrame.paragraphs.item(0).words.item(0).appliedCharacterStyle =
      myDocument.characterStyles.item('foo');
      I know, I haven't set up any sort of loop yet (which will be trickier given the fact that there will be blank versos, etc). What I'm trying to do in this is to select the first word in the first paragraph on the second page--which it does in fact do. Problem is, the first paragraph on the second page starts on the first page, so I'm selecting that a word on the first page, not the second page.
      As I said, lots of work to do but a little help on getting to the right word would be most appreciated.
        • 1. Re: [JS][CS3]Applying Character Style to First Word
          You don't have to refer to paragraphs, you can immediately use words:
          alert ("["+app.selection[0].parentTextFrames[0].words[0].contents+"]");
          always shows the first word in your current text frame. Do note, however, that a word may be split due to hyphenation (it shows the entire word). An additional, eh, 'feature' (?) is that blank lines are ignored. A good solution, however, would be to go one step down and use characters:
          alert ("["+app.selection[0].parentTextFrames[0].characters[0].contents+"]");
          • 2. Re: [JS][CS3]Applying Character Style to First Word
            reedkm_unc Level 1
            Excellent, thank you. I take your point about hyphenation, and I'm working with just the first character.
            Now to work through the looping; should be straightforward enough.
            • 3. Re: [JS][CS3]Applying Character Style to First Word
              reedkm_unc Level 1
              Okay, perhaps I can ask for a little bit more guidance?
              I have this (I know, perhaps a bit verbose):
              for (var i = myDocument.pages.length-1; i >= 0; i--)
              var myPage = myDocument.pages.item(i);
              var myText = myTextFrame.characters.item(0);
              var myWord = myText.parentTextFrames[0].characters[0];
              myWord.appliedCharacterStyle=
              app.activeDocument.characterStyles.item('foo');
              which works nicely as long as there is a text frame on every page. As I mentioned, there will be blank versos, graphics, etc., along the way, so I want to skip those.
              I've been trying if statements such as
              if (!myText)
              exit()
              and other variations to see where the logic should work, but I'm missing something.
              Again, much thanks!
              • 4. Re: [JS][CS3]Applying Character Style to First Word
                It's as straightforward as anything in InDesign. Well, up to a certain point
                Every document has a Pages array so you can use .length to loop over all. The pages do not correspond to 'page numbers', as these are fleety things. The array starts at '0' for the first page and continues to the end of the doc.
                Similarly, each page can immediately refer to its contents -- in this case you want just the TextFrames. Do not use PageItems, as this holds "all" items, including graphics, lines, circles and whatnot. You can loop over all of these text frames inside the pages loop.
                Wanna have a go at it yourself?
                • 5. Re: [JS][CS3]Applying Character Style to First Word
                  reedkm_unc Level 1
                  But of course! I appreciate the help. I think I'm following you, and will keep at it.
                  • 6. Re: [JS][CS3]Applying Character Style to First Word
                    Well, you were on the right track, but testing 'myText' fails if there is no text frame on a page because it fails one line earlier
                    just before this, you should test the number of text frames:
                    if (myPage.textFrames.length > 0)
                      ... your stuff ..
                    Only use this if you are absolutely positive there is just a single text frame on each page! A slightly better way would be to always loop over each textframe:
                    for (frames=0; frames<myPage.textFrames.length; frames++)
                      var myTextFrame = myPage.textFrames.item(frames);
                      ..etc.
                    in which case you also don't have to test its length first (the loop will not be executed if there are zero text frames).
                    [Techy] Since you have only one continuous story, an even better way would be to loop over the textframes of that story alone. You have to identify the story somehow, and I usually click the text cursor in the one I need:
                    myStory = app.selection[0].parentStory;
                    or you can rely on the fact that the story starts in the only text frame on page 1:
                    myStory = app.activeDocument.pages[0].stories[0];
                    (I think that oughta work.) Then, each frame of this story up till the end can be found in the array
                    myStory.textContainers
                    which are usually text frames. You can loop over these using
                    for (frame=0; frame<myStory.textContainers.length; frame++)
                      myTextFrame = myStory.textContainers[frame];
                    ..etc.
                    • 7. Re: [JS][CS3]Applying Character Style to First Word
                      reedkm_unc Level 1
                      Sorry for the delay in responding, and thanks very much for your help. It's working exactly as it should! I'm just trying to resolve implications--i.e., it's doing what I asked, but I'm not so sure I should have asked it to do that!
