4 Replies Latest reply on Oct 6, 2009 3:02 AM by ramkumar.vp
    color removal
    Seth McGraw
      How can you (javascript) add unnamed colors and then subsequently select and delete unused colors in CS & CS2.
      In CS3 & 4 I can do it through menu actions (not supported in CS & CS2
        • 1. Re: color removal
          You can't add unnamed colors in Javascript. Rather, that's what I learned, the hard way. But ...
          Devious!
          Well ... as you said ... not in those older versions. Why not make up a name on the spot? It doesn't matter for its 'unused' status.
          The unused swatches can be found as a document property "unusedSwatches":
          Array of SwatchreadonlyThe swatches that are not being used.
          (you gotta love those helpful descriptions).
          Search the forum, I might of made someone else a working 'delete unused' script.
          [Edit] Got it; it's part of the script here: http://forums.adobe.com/thread/491014?tstart=1
          • 2. Re: color removal
            Seth McGraw Level 1
            Not sure what part to use...clarify?
            • 3. Re: color removal
              Ah -- I see I used it the other way around (generating a list of used colors from the entire document swatch list -- and I was pretty content with this!).
              Off top of head, you might aim at sth like:
              while (app.activeDocument.unusedSwatches.length > 0)  app.activeDocument.unusedSwatches[0].remove();
              As you keep on removing item #0 (the first), the unusedSwatches array should decrease in length until it disappears into the tiny black hole inside your computer (leaving just its name and a zero length array as a lingering singularity).
              Untested, so it might object against stuff like mixed inks. Pretty sure it would work with fairly regular color swatches, tho'.
              • 4. Re: color removal
                ramkumar.vp Level 3
                Hi Seth / Jongware,
                I think this method will only work for normal swatches.
                In case of Gradiant swatches [manualy CMYK color applied] it wouldn't work, because of unnamed colors.
                So before deleting the swatch check its name not as empty.
                Sample Code:
                var myDocument = app.activeDocument;
                var found=0;
                var arrUnusedSwt=myDocument.unusedSwatches;
                for(var jj=arrUnusedSwt.length-1;jj>=0;jj--)
                     try{
                          if(arrUnusedSwt[jj].name.toString()!=""){arrUnusedSwt[jj].remove();}
                     }catch(e){}
                Regards,
                Ramkumar
