6 Replies Latest reply on Oct 12, 2009 9:48 PM by Yuliaart
    How to inforce specific color settings in InDesign CS4 js
    Yuliaart
      Hi, I need to set specific color settings when creating a pdf from InDesign in Java script (not as a preset). What I found in previous discutions is:
      #target InDesign
      app.ColorSettings.cmsSettings="MyColorSettings";
      ( in the Forum
      http://forums.adobe.com/message/1108248#1108248),
      which just somewhat make sence to me.
      I saved my MyColorSettings.csf file in color settings folder, but I am not sure how to tell the script to access it, and I am not sure that that's the only
      reason why the lines abouve don't work.
      Thank you for your help.
      Yulia
        • 1. Re: How to inforce specific color settings in InDesign CS4 js
          Kasyan Servetsky Level 5
          'C' in colorSettings should be lowercase:
          app.colorSettings.cmsSettings = "MyColorSettings";
          • 2. Re: How to inforce specific color settings in InDesign CS4 js
            Yuliaart Level 1
            Hi, thank you for clarification. I still need more help with it to make it work. So I have from OMV:
            app.colorSetting.cmsSettings="MyColorSettings";
            app.colorSetting.cmsSettingsList;
            app.colorSetting.cmsSettingsPath= File (Folder.desktop + "/PS_Hotfolder" + "/scripts" + "/MyColorSettings.csf");
            I am not sure how to make all of that to work together and I think I need an action to actually set/activate the settings.
            Thank you so much for your help.
            Yulia
            • 3. Re: How to inforce specific color settings in InDesign CS4 js
              Is the same as going to Edit > Color Settings in user interface and choosing "MyColorSettings" in Settings drop down.
              app.colorSetting.cmsSettingsList; — gives you a list of all available color management system settings — the same as in the above-mentioned drop down.
              cmsSettingsPath is the file path of the CSF file to use.
              As far as I understand, you should save your Color Settings in user interface first and then set it by script like so:
              if (IsInArray("MyColorSettings", app.colorSettings.cmsSettingsList)) {
              else {
                  alert("Color setting named \"MyColorSettings\" doesn't exist. Create it and try again.");
                  exit();
              function IsInArray(myString, myArray) {
                  for (x in myArray) {
                      if (myString == myArray[x]) {
                          return true;
                  return false;
              Notice that I check if it exists before applying it.
              • 4. Re: How to inforce specific color settings in InDesign CS4 js
                Yuliaart Level 1
                Thank you, Kasyan, very much. It works very well with file saved on my computer, now I need the scritp to be able to find that file on the server, so it could be accessed by anybody in the office. Here what I did, and I am not sure if I am defining the path correctly:
                if (IsInArray("NDF_CmSetting_indd", app.colorSettings.cmsSettingsList)) {
                    app.colorSettings.cmsSettings = "NDF_CmSetting_indd";
                    app.colorSettings.cmsSettingsPath = "/SPACE" + "/ Prepress" + "/Export settings" + "/InDesign CS4" + "/ShowPDFoptions_CS4.jsx";
                else {
                    alert("Color setting named \"NDF_CmSetting_indd\" can't be found. Please log into SPACE");
                    exit();
                            return true;
                    return false;
                Thank you very much.
                Yulia
                • 5. Re: How to inforce specific color settings in InDesign CS4 js
                  Yulia, everything wrong in your script: first of all, setting cmsSettings and cmsSettingsPath at the same time makes no sense — this is the same as choosing a setting in Color Settings dialog and then clicking the Load button and selecting another setting — the second cancels the first. So, you need to set only cmsSettingsPath property. If you take a look at this property in OMV, you'll see that it requires File not String, as you are trying to set.
                  I would use the following code:
                  var myPath = "/Volumes/SPACE/Prepress/Export settings/InDesign CS4/ShowPDFoptions_CS4.jsx";
                  var myFile = new File (myPath);
                  if (myFile.exists) {
                      app.colorSettings.cmsSettingsPath = myFile;
                  else {
                      alert("File \""+ myPath + "\" can't be found.");
                  You don't mention if you use Mac OS or Windows, or both at your work.
                  On Mac volume name should be prepended with "/Volumes":
                  /Volumes/Remote/dir/file
                  On Windows, to access a remote volume, use a uniform naming convention path name of the form
                  //servername/sharename.
                  Or, if you have a mapped network drive:
                  /Z/foldername/foldername/filename
                  Where Z is a letter corresponding to your drive.
                  To find out the path to a file, you can also use the following script:
                  myFilePath = File.openDialog("Locate the file");
                  $.writeln(decodeURI (myFilePath));
                  It writes the path of the chosen file to console
                  Kasyan
                  • 6. Re: How to inforce specific color settings in InDesign CS4 js
                    Yuliaart Level 1
                    Thank you, Kasyan.
                    It's working now, and we are already using it. And yes we are on Mac.
                    Thank you very much for your help.
                    Yulia
