0 Replies Latest reply on Oct 6, 2009 10:30 AM by Carol L. Frampton
    [svn:fx-trunk] 10889: Add FTETextTests which check that a Label and NumericStepper configured to use FTEText have a textField and textInput , respectively, of type UIFTETextField and MXFTETextInput.
    Carol L. Frampton Level 2
      Revision: 10889
      Author:   cframpto@adobe.com
      Date:     2009-10-06 09:29:53 -0700 (Tue, 06 Oct 2009)
      Log Message:
      Add FTETextTests which check that a Label and NumericStepper configured to use FTEText have a textField and textInput, respectively, of type UIFTETextField and MXFTETextInput.  The components are configured via style properties rather than by theme which would require another version/compile of the BasicTests.swf.
      QE notes:
      Doc notes:
      Bugs:
      Reviewer: Alex
      Tests run: basictests
      Is noteworthy for integration: no
      Modified Paths:
          flex/sdk/trunk/frameworks/tests/basicTests/BasicTests-config.xml
          flex/sdk/trunk/frameworks/tests/basicTests/BasicTests.mxml
      Added Paths:
          flex/sdk/trunk/frameworks/tests/basicTests/halo/scripts/FTETextTestScript.mxml
          flex/sdk/trunk/frameworks/tests/basicTests/halo/views/FTETextTests.mxml
