3 Replies Latest reply on Oct 7, 2009 5:42 AM by lee704
    Dynamically select all rows in a DataGrid
    lee704 Level 1
      Is there a simple way to dynamically select all rows of a DataGrid control?  I'd like to select all the rows as soon as the DataGrid is created.
      Thanks!
      Lee
        • 1. Re: Dynamically select all rows in a DataGrid
          Gregory Lafrance Level 6
          This code should answer your question.
          If this post answered your question or helped, please mark it as such.
          <?xml version="1.0"?>
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
             initialize="initData()" creationComplete="init();">
             <mx:Script>
             <![CDATA[
              import mx.events.ListEvent;
                import mx.collections.*;
                private var DGArray:Array = [
                   {Artist:'Pavement', Album:'Slanted and Enchanted', Price:11.99},
                   {Artist:'Pavement', Album:'Brighten the Corners', Price:11.99}];
                [Bindable] public var initDG:ArrayCollection;
                public function initData():void {
                   initDG=new ArrayCollection(DGArray);
                public function init():void{
                 var arr:Array = new Array();
                 for(var a:uint=0;a<myGrid.dataProvider.length;a++){
                   arr.push(a);
                 myGrid.selectedIndices = arr;
             </mx:Script>
             <mx:DataGrid id="myGrid" width="350" height="200"
                dataProvider="{initDG}">
                <mx:columns>
                   <mx:DataGridColumn dataField="Artist" />
                   <mx:DataGridColumn dataField="Album" />
                   <mx:DataGridColumn dataField="Price" />
                </mx:columns>
             </mx:DataGrid>
          </mx:Application>
          • 2. Re: Dynamically select all rows in a DataGrid
            lee704 Level 1
            Excellent example Greg.  Thank you!
            • 3. Re: Dynamically select all rows in a DataGrid
              lee704 Level 1
              As a follow-up...
              What if I only wanted to select the rows where the rows met a certain criteria like Column B > 0?
              For example, I have a DataGrid with 2 columns: Column A and Column B.  The DataGrid had 10 rows of data, but only 5 rows have data that meet the criteria specified (Column B > 0).
              Can you provide a suggestion for doing this?
              Thanks!
