2 Replies Latest reply on Oct 9, 2009 6:48 AM by Cuk26
    Few problems that I have while doing Flex4beta IAW
    Cuk26
      Hello
      The first problem that I've come across in Flex 4 beta in a week was with the dropDownList in my form.
      Somewhere along this video:
      the "change" property is added but for some reason I dont have that property in my DropDownList.
      The code hinting doesnt show it and i get an error if i write it.
      (Cannot resolve attribute 'change' for component type spark.components.DropDownList.)
      I have the latest version and I can't import this:
      import spark.events.IndexChangeEvent;
              <mx:FormItem label="Branch:">
                  <s:DropDownList
                      id="Branch"
                      width="128"
                      dataProvider="{branchesData}"
                      labelField="region"
                      change="branch_changeHandler(event)"  <------ this
              </mx:FormItem>
      The second thing i noticed is the Label component
      The girl in the movie has it in the spark namespace, I have it in mx namespace
      <s:Label />
      <mx:Label />
      Thanks for help
      Anze
        • 1. Re: Few problems that I have while doing Flex4beta IAW
          e2dev Level 2
          Anze - I just downloaded the beta 2 release of Flash Builder and downloaded the big day zip and looked at ex1_03_solution. Is that what you're looking at? It works fine for me with the import statement and the change event you mention.
          Can you verify what build you're using? Select Help > About Adobe Flash Builder 4. The build number should be 253292.
          Also, re: the spark vs MX for Label. Both will work, but Spark is the new component library for Flex 4 so that's preferable over MX. Not all components are available in Spark yet, though, so sometimes you have to use MX. If given a choice, though, select Spark.
          If you post your code, I can take a look for you.
          HTHs.
          • 2. Re: Few problems that I have while doing Flex4beta IAW
            Cuk26 Level 1
            Hello
            Yes, my mistake. For some reason I had the shortcut for the olderversion on the desktop instead of the new one.
            Works perfect.
            Thanks, Anze
