3 Replies Latest reply on Oct 8, 2009 7:32 AM by kglad
    Movieclip control
    Rootle
      I've almost got a bit of flash finished, I am hoping someone can help me make a bit of code to finish it off. The .swf so-far is here: http://www.samhumphrey.co.uk/new/clock2.html
      ..for some reason the file won't attach but the important bit of code I have so-far is below.
      I need to make a line to litterally 'connect the dots', each of which is one end of a movieclip, I know it needs to boil down to ' line x,y, to (movieclipname)x,y, but cannot work it out!
      Thanks, R.
      time.onChanged = function()
      if(time.text.length == 4) {
      var hours:Number = parseInt(time.text.substr(0,2),10);
      hours *= 60;
      var minutes:Number = parseInt(time.text.substr(2,2),10);
      minutes += hours;
      while(minutes > 720) {
      minutes -= 720;
      var lineNum:Number = Math.ceil(minutes/12);
      /*trace(lineNum);*/
      _root["line"+lineNum]._xscale += 20;
      _root["line"+lineNum]._yscale += 20;
        • 1. Re: Movieclip control
          if you're trying to draw a line from x1,y1 to x2,y2 using actionscript, use:
          this.createEmptyMovieClip("lineMC",this.getNextHighestDepth());  // <-unless you're using v2 components
          with(lineMC){
          lineStyel(1,0xff0000);
          moveTo(x1,y1);
          lineTo(x2,y2);
          • 2. Re: Movieclip control
            Rootle Level 1
            I'm not sure what vs components are, but I tried something similar to this, but it didnt work because the spots move out in all directions, so I can't just add a value to the x and y value.
            Ids there some way i can combine this with a bit of code that finds the x and y value of the end of each spot movieclip? - as I could then use your suggestion as:
            (lineMC){
            moveTo(foundvalue x1,foundvaluey1);
            lineTo(new foundvalue x2, new y2);
            • 3. Re: Movieclip control
              if you're trying to draw a line from dot1MC to dot2MC, use:
              with(lineMC){
              moveTo(dot1MC._x,dot1MC._y);
              lineTo(dot2MC._X, dot2MC._x);
              and if you want to do that repeatedly because dot1MC and/or dot2MC are moving, repeatedly call lineF(lineMC):
              function lineF(mc:MovieClip){
              with(lineMC){
              clear();
