1 Reply Latest reply: Oct 7, 2009 11:37 AM by Arnis Gubins RSS
    fix for chapter numbering?
    zeppm Community Member
      I use Frame 8.  I have a book with four chapters, and I added one between 1 and 3.  The autonumbering changed the order to Chapter 1, Chapter 3, Chapter 1, Chapter 3.
      I have tried to use the Document -> Pagination window to tell it to "continue from previous" or put in the number I specify. I've also tried the same thing with the whole book.  Strangely but happily, the TOC does the numbering perfect when I update the book.  I have also tried importing formats from another document with correct numbering.
      Any ideas?
      Thanks!
        • 1. Re: fix for chapter numbering?
          Arnis Gubins CommunityMVP
          You have to set the numbering at the Book level. Book settings always trump Document settings. Select all files in the Book, right-click and select Numbering. Set the Chapter tab to Continue from previous, provided you're using the <$chapnum> variable.
