0 Replies Latest reply on Oct 7, 2009 11:40 AM by aponnusa
    AS3 asdoc inheritance issue.
    aponnusa Adobe Employee
      I have an API that inherits flash.display.Sprite .When I try to generate the ASDocs for the API, The ASdoc shows that my class inherits from flash.display.Sprite, but doesnt link or there is no click-able link to the Sprite's ASDoc. Can anyone tell me what I am missing.
      The command I am using in my ant script is
      <target name="main" depends="clean, createTemp" description="generates the asdocs for the project">
        <java jar="${asdoc.jar}" dir="${FlexSDK.dir}/frameworks" fork="true" maxmemory="256m" failonerror="true">
           <arg line='-load-config "${flex-config.xml}"'/>
           <arg line='-source-path ${src.dir}'/>
           <arg line='-doc-sources ${src.dir}/com'/>
           <arg line='-output ${docs.dir}'/>
           <arg value='-library-path+=${FlexSDK.dir}/frameworks'/>
      Thanks in advance for your help.
