5 Replies Latest reply on Oct 8, 2009 8:02 AM by the_wine_snob
    Videocard for PME 7.0
      Can somebody advise me an videocard for the program. Im using it for edit sd-material so it's not very exciting . But are there any (budget) cards that perform well. Wich series do i have to look for? And aTi or nVidia?
        • 1. Re: Videocard for PME 7.0
          Virtually all video cards are made by either ATI or nVidia -- but stick with these two brands anyway.
          Beyond that, the program is not terribly video card intensive. Even a 128 meg card is good enough.
          Try to get a card that includes pixel shading, however. That way you can use some of the more advanced GPU effects and transitions in the program.
          • 2. Re: Videocard for PME 7.0
            the_wine_snob Level 9
            I also responded to this request at the end of another thread.
            Basically, I said the same thing as Steve did, but he added the Pixel Shading aspect, that I had not thought about.
            Good call Steve.
            • 3. Re: Videocard for PME 7.0
              A.T. Romano Level 7
              According to the Adobe information, I do not believe that a GPU with just Vertex Shader is going to work. Please read further.
              I would offer the following into the mix if you are trying to use the GPU Effects in Premiere Elements 7 or 8, namely, Page Curl, Refraction, Ripple (Circular). Same considerations for Premiere Elements 7 and Premiere Elements 8.
              GPU must support:
              DirectX 9.x and
              Pixel Shader (PS) 1.3 or later and
              Vertex Shader (VS) 1.1 or later.
              Refer to GPU Effects in Premiere Elements 7 or 8 Help PDF. A link to the version 8 Help PDF on the GPU Effects is posted below. Same as version 7.
              http://help.adobe.com/en_US/PremiereElements/8.0/Win/Using/WSFB1985CE-8FA4-4d7d-B1E6-79C45 B014627.html
              • 4. Re: Videocard for PME 7.0
                Pietjooo Level 1
                Thank you for the reply's. But cac somebody give me some serie to look fot. such as ati 3450/4550/4670 . I dont know much about videocards and in the other topic you can see i have problems with a hd 3300. So if somebody has a card that works with no problems please tell me the productname, so i can buy it.
                • 5. Re: Videocard for PME 7.0
                  Wish that I could help, but one of my nVidias is on my laptop, GeForce 8800m GTX, and the others are high-end nVidia Quadros, for 3D work. These are far more card, and far more expensive, than what you need.
                  I hope that others can help you more directly.
