4 Replies Latest reply on Nov 2, 2009 12:35 PM by tofer.curtis
    VBox not scrolling
    Zolotoj Level 3
      I have a VBox with ToggleButtonBar:
      <mx:HBox width="100%" height="50%" backgroundColor="#F5F5F5" id="B2">
      <mx:VBox id="B1" borderStyle="solid" height="100%" width="110" verticalScrollPolicy="on">
           <local:portalDepartments itemClick="departmentClickHandler(event)">
           </local:portalDepartments>
      </mx:VBox>
      <mx:ToggleButtonBar direction="vertical"
      xmlns:fx="http://ns.adobe.com/mxml/2009" creationComplete="buildDepartments()"
      xmlns:s="library://ns.adobe.com/flex/spark" width="100" initialize="init()"
      verticalGap="2" fontSize="9" paddingRight="10" paddingLeft="10" height="100%"
      xmlns:mx="library://ns.adobe.com/flex/halo" labelField="name" buttonHeight="45">
      What's happening is that even B1 will have a vertical scrollbar but something still would push the outer B2 to get a scrollbar and scroll B1.
      What I want is to be able to scroll B1 to show all buttons of ToggleButtonBar.
        • 1. Re: VBox not scrolling
          Zolotoj Level 3
          This is really an annoying problem. Anybody, please help.
          • 2. Re: VBox not scrolling
            mattcom Level 1
            This may or may not help.  I had the same problem with a very tall application.  I ended up finding an autolayout property in the A-Z properties box that I set to true and then I got a scroll bar. So, try adding
            autoLayout=" true"
            to your VBox.
            • 3. Re: VBox not scrolling
              Zolotoj Level 3
              I tried, did not help. The only thing that helps is if I set box's height to some value like 300. Percent does not work.
              • 4. Re: VBox not scrolling
                tofer.curtis
                This is very annoying to me too. The way I got around the problem was to bind the height property to another component. In my case, I wanted the vbox to match the height of the component (a canvas) so:
                <mx:VBox id="labelListBox" height="{this.height}" verticalScrollPolicy="auto" x="0" y="0" width="200" />
                or if you could probably do something a little more complicated (not tested):
                <mx:VBox id="vb1" width="100%" height="100%>
                <mx:HBox id="hb2" height="150" width="100%" />
                <mx:HBox id="hb3" height="{vb1.height - hb2.height}" width="100%/>
                </mx:VBox>
                Good Luck,
                Chris
